| Home > Help Needed / General Tech Chat > Buggered starter solenoid? | |||||||
2nd May, 2009 at 07:34:29pm
Hi guys,
Edited by richminiturbo. on 2nd May, 2009. |
2nd May, 2009 at 08:37:46pm
Simple test - but do it carefully - a screwdriver across the two big lugs
2nd May, 2009 at 08:39:47pm
Ok i'll give it a go in a sec, just going to knock up a will. |
2nd May, 2009 at 08:53:45pm
On 2nd May, 2009 richminiturbo. said:
just going to knock up a will. Feel free to put me in it :) Schrödinger's cat - so which one am I ??? |
2nd May, 2009 at 08:56:53pm
Leave me the skid bus. |
2nd May, 2009 at 09:11:33pm
Good news guys, i'm alive. :) (if that's good news to you, im unsure!)
2nd May, 2009 at 09:29:57pm
Assuming your DVM is set to continuity, it's the one that reads "1" or bleeps that is the operating coil.
2nd May, 2009 at 09:34:56pm
I started my car by bridging the terminals like that for months! Those were the days... On 7th Nov, 2008 Nic said:
2nd May, 2009 at 09:40:24pm
Oki doki thanks Rod.
On 2nd May, 2009 Jay#2 said:
I started my car by bridging the terminals like that for months! Those were the days... Haha thats ultra-ghetto! Edited by richminiturbo. on 2nd May, 2009. |
2nd May, 2009 at 09:54:24pm
It doesn't matter about the connections to the two little spades when doing the screwdriver test as you are quite litteraly bypassing the function of the solenoid - if the ignition is turned on and the starter motor works and is not stuck or shorted, the engine will start irrespective of the little tags.....
2nd May, 2009 at 10:14:16pm
Ahhhh I see.
3rd May, 2009 at 12:44:43pm
I've now given the starter a few good clouts and hooked it up to the battery on the driveway....
Edited by richminiturbo. on 3rd May, 2009. |
3rd May, 2009 at 12:59:11pm
Assuming battery was fully charged (and not knackered), looks like it's dead.....
Edited by Rod S on 3rd May, 2009. Schrödinger's cat - so which one am I ??? |
3rd May, 2009 at 03:35:28pm
I took the starter motor apart to find fairly coroded internals which I cleaned up with contact cleaner and put it all back together.
3rd May, 2009 at 03:55:06pm
You're not having a lot of luck.....
3rd May, 2009 at 04:12:23pm
Yeah the whole lot spins freely enough, spinning up really quickly when on the battery.
3rd May, 2009 at 04:46:25pm
Right, if you put the "new" starter on the drive (as per your video) and touch the jump lead you should,
7th May, 2009 at 06:03:58pm
Ok doki.
7th May, 2009 at 06:08:38pm
What year is the car (specifically the loom it was taken from another car). Schrödinger's cat - so which one am I ??? |
7th May, 2009 at 06:16:29pm
As far as I know its the loom that's original to the car which is a 1990 mayfair I think! |
7th May, 2009 at 06:47:19pm
In which case the wiring was originally intended for a pre-engaged starter motor, not inertia....
7th May, 2009 at 07:03:50pm
Thanks Rod!
Edited by richminiturbo. on 7th May, 2009. |
7th May, 2009 at 07:27:14pm
White/brown is wrong.... are you sure it's not white/yellow (in which case it's the ballast bypass) but take it off for the moment.
7th May, 2009 at 08:10:06pm
Rod, i've just taken the white/red out of the relay and ran it directly to the correct spade on the solenoid - hey presto it works!!!
7th May, 2009 at 08:15:54pm
result! "Turbo's make torque, and torque makes fun"
