Home > Help Needed / General Tech Chat > Clutch Slave cylinder
Guennie
Member #: 2328
Nr Newmarket, Suffolk
Hi again guys, just a couple of questions on the clutch. I have a pre verto setup on my new engine. This didn't come with a slave cylinder or slave cylinder bracket.
my questions are;
Should there be a mounting braket for the slave cylinder? (sililar to verto clutch)
and
Can i use the slave cylinder from my old engine (verto)?
thanks in advance
Guennie
100% BMW Free
Turbo Shed
Member #: 30
Epsom, Surrey
the pre verto slave bolts to the transfer gear casing.
it has been known for people to use the verto slave on a pre-verto set up but you really should pay the peanuts and get the right part
As above, it bolts straight on (no bracket) but apart from a slight size difference, the real issue is the verto one doesn't have the tag for the return spring - pre-verto has a return spring to hold the longer arm against the adjustable return stop whereas the verto is self adjusting so doesn't have a return spring and stop.
Guennie
Member #: 2328
brilliant! for £20 or so from mini spares i guess i'll order one today!
100% BMW Free
When you order, check it's supplied with the return spring tag - sometimes they are not (they assume you already have one) - it is sandwiched between the bleed nipple and the body of the cylinder.
Guennie
Member #: 2328
ok, will do :) thanks again Rod! full of useful info yet again!
100% BMW Free
Guennie
Member #: 2328
ok so is this the tag im after?
http://minispares.com/Product.aspx?ty=pb&p...SPRING%20ANCH...
if so i guess i may as well get the spring as well.
100% BMW Free
graemec
Member #: 1424
Carnforth, Lancs
No - that's the one on the end of the arm (although you may need that too?)
I think the egg shaped tag on the slave cylinder is NLA and they invariably don't come with one. Bit if a bugger as they are easily lost!
Also check the bleed nipple (depending on how you feel about having to find/use metric spanners when working on minis) as they normally seem to come as 10mm A/F rather than the origninal 3/8" A/F
graemec
Member #: 1424
Carnforth, Lancs
For reference the part number of the NLA tag is 23600
You may get one from somewhere who also deals in secondhand parts - Somerford, Min-e-Bitz etc? Or a Wnated ad on here?
As Graham says.
Also piccy near the end of this thread.
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=267888
Guennie
Member #: 2328
So i can use my current verto cylinder to get the engine up and running but it's worth changing to the correct one asap?
100% BMW Free
Two issues (apart from the minor size difference)
1 - the hose comes out in a different direction so it is hard to get the hose to run right (it uses a banjo connector (90 degrees) rather than a straight connector)
2 - it doesn't have the tag for the return spring - there is a big lug at the back that you could bodge a spring to fit over, but not the standard spring...
Yes, it's possible, but not right......
I made a tag for the slave cylinder from an M10 penny washer, cut it to shape and drilled a small hole for the spring. Jobs a gud un
Turbo Shed
Member #: 30
Epsom, Surrey
i binned the return spring and now the clutch pedal is higher and never needs adjusting
Guennie
Member #: 2328
Have ordered a new one now :)
100% BMW Free
