Home > General Chat > Back working bhp from 1/4 times.
Sam
Member #: 1686
Oxford
Allo all. Im trying to backwork my bhp now ive taken off my weber and im back on a mechanical fuel pump.
15.4 @ 90mph measured using a vbox racelogic thing on an abandoned air strip.
The mini is 650kg without my lardy arse in it. Probably 740ish with me in it.
Its a 1293 with a 296sp and a 3.77 diff if thats any help.
Thanks
Sam.
OMG Robert that's a big one
There are so many variables Sam un less you have full traction off the line (we don't) it's not really possible to work out with any accuracy.
you may find this flight of fancy interesting sam .
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=140029
evolotion
Member #: 83
Glasgow, Scotland
i have compared the last 1/8th mile of various cars to get an idea of power/weight :)
Denis O'Brien.
Trap speed and vehicle weight are the important bits...assuming a sensible run with no cocked up gear changes.
ET doesnt really figure in HP calculators...or at least it shouldnt. Trap speed's do generally be fairly consistent for a given power level though ( unless gearing is particularly bad )
SidewaysGTM
Member #: 5022
Oxford, Kings Lynn, Pod, Pub.
Second,,,,what Stevie said trap speed and weight
WEST
Got A GTM With A Honda In the Back, and huge Nitrous bottle where the passenger seat should be when racing!
On 19th Oct, 2009 Nic said:
Ill donate to the cause if you can make it do wheelies!!
Sam
Member #: 1686
Oxford
Thanks fellas. Robert i think your graph is a little optimistic.
*surprised* never diss the graph master! *wink*
That graph is nearly spot on with my speed Vs power....even with a 3 sec 6ft! *hehe!*
HHAHAHAHA,very funny .
optomistic in which way sam ? too much power or too much speed ?
Sam
Member #: 1686
Oxford
Sorry im being dopie i forgot your working with 750kg as your weight.
It did a 14.6 with a terminal of 96 mph at Santa pod. With 118bhp so a power to weight ratio of roughtly 180bhp per tonne.
So take the power to weight and divide it by the terminal time gave me 1.88541666666666.
So
power = ((terminal / 1.88541666666666) / 1000) x weight)
For a 100mph terminal time I’ve put in a 8 percent correction. To take into account of air resistance.
Power = ((terminal / (1.88541666666666 x 1.08)) / 1000) x weight).
So for my car to run 100mph terminal it would need 132bhp. If you look at other fwd cars running that time it’s about 14 seconds over the 1/4. With a power to weight ratio of 203bhp/tonne. I worked out 203.625. So not too far off the mark.
Dont forget to include your weight
Sam
Member #: 1686
Oxford
Ah true. fuck it. crash course diet then.
