Home > General Chat > fog lights for MOT (edit MOT in 40 mins :-0 )
MarkGTT
Member #: 1194
Shropshire.
Hi, Is it true that a rear fog light must only be fitted to a vehicle first used on or after 1st April 1980? (mot rules)
mine has decided not to work but i have a '78 car.. so could just take it off.
Edited by MarkGTT on 23rd May, 2009.
Oli
Member #: 1910
Wilts
You are correct, you can just remove it.
yes if it's fitted it has to work, other wise remove it.
Turbo Shed
Member #: 30
Epsom, Surrey
dump that crap, you dont need it
i have one, does look shit though *wink*
MarkGTT
Member #: 1194
Shropshire.
off it comes! and your right it did look shite.
Taking it of will make the car lighter!
leroymornsey
Member #: 5265
telford
dont go to ability by us mate failed mine on fog lamp and no side repeaters and headlamp aim was bit out what a wanker he looks a bit like penfold off danger mouse
garlic bread
If your removing it, make sure you remove the switch as well
I've wired up one of my reversing lights as a fog so I don't have the seprate one hanging off
good thinking Rob.
MarkGTT
Member #: 1194
Shropshire.
Lol, its booked in at Madley test centre.
Fog light is now working again, so will leave it on due to the switch being live. It will be removed after MOT test .. and the switch wil be used for something else :)
cheers chaps.
fordimus maximus
Member #: 1357
telford,shropshire
sorted a flasher unit mate, also another job to add to the list the return on fuel tank.
MarkGTT
Member #: 1194
Shropshire.
sorted both tonight mate.
just have to bolt the fuel pump down and fix the battery box in place and im good to go!
fordimus maximus
Member #: 1357
telford,shropshire
nice 1, dnt forget wen it passes to come pick me up.ive got to hear that straight cut wine again!!
MarkGTT
Member #: 1194
Shropshire.
40 mins until MOT time.. and im shitting bricks.
everyone cross something for me :)
good luck mate, :)
MarkGTT
Member #: 1194
Shropshire.
well i didnt get to the mot station.. no idea what the problem is but im not happy.
Ben.
Member #: 1064
Formally Whyte_ben
Horndean, Hampshire
Oh dear, is it not running then? Sorry to hear that!
Build Thread Click Here
PaulH
Member #: 2340
Dublin Ireland
Well there is always next Time get to the postmortem dood You will feal beter Knowing what's wrong
On 17th Feb, 2009 Rob H said:
MarkGTT
Member #: 1194
Shropshire.
drive flange issue on off side.. there was a knocking sound that turned out to be the wheel almost coming off!
easy to sort.. but a bit shit. Looks like the tread was shot for a wheel nut.
next seems to be an intermittent issue with the fuel pump, causing the car to cut out.
Now, last night i mounted this vertically i don’t think it likes it..
fecking minis!!!
lockfast
Member #: 2775
Aberdeen
What pump are you using? My friend had a similar thing with a fuel pum on is nova and it turned out he was running it the wrong way! Might be worth a look? And sorry is it is a bit like stating the obvious?
MarkGTT
Member #: 1194
Shropshire.
all sorted now.. i hope.
it wasnt that iw as running the pump in the wrong direction but the way i had it mounted.
MOT rebooked for begining of next month.
