| Home > Technical Chat > Audi TT Intercooler results | |||||||
147 Posts Member #: 814 Advanced Member Utrecht, The Netherlands |
21st Jun, 2009 at 04:56:16pm
I've installed two air temp sensors today to test the IC efficiency. One measures the air temp before the IC the other one the temp after the IC.
21st Jun, 2009 at 05:59:27pm
How much boost ? I'm surprised how low the temps are before the IC 9.85 @ 145mph
21st Jun, 2009 at 06:08:28pm
On 21st Jun, 2009 MrTurbo said:
running 15 psi of boost, 160 kmph (on a private road) for 5 minutes: Stevie ^^^^
Sounds like its working a treat! Edited by matty on 21st Jun, 2009. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
21st Jun, 2009 at 06:08:48pm
I have measured the temp at 15psi of boost. The airfilter is behind the grille as well, so the coldest air possible is sucked in. I guess that helps keeping the air temp before the IC a bit colder. |
21st Jun, 2009 at 06:15:27pm
You should measure the temps in the turbo inlet the the turbo outlet. The move the sensors to the IC inlet then IC outlet. That way it will give you an idea how efficient the turbo is, and the IC efficiency. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
21st Jun, 2009 at 07:02:57pm
top stuff mr turbo have you any pics of the intercooler install ?
21st Jun, 2009 at 07:07:11pm
21st Jun, 2009 at 07:30:28pm
That 40 degree drop against a 50 degree difference means that it working at 80% efficiency.
21st Jun, 2009 at 08:20:32pm
hmm, funny, never thought of that spotlight being in the airstream of the IC.. I will remove it to see whether there is any difference.. |
![]() 362 Posts Member #: 114 Senior Member Porto/Portugal |
30th Mar, 2013 at 09:19:30pm
Pedro Silva
![]() 143 Posts Member #: 2764 Advanced Member Halesowen |
14th May, 2013 at 02:12:41pm
Airflow at 100mph will be quite high - have you done any tests at lower speeds, like tight country lanes where you are only doing around 50-70mph but involve a lot of acceleration/braking? 1994 Mini Mayfair, 1330, Mspd Ph2 cam, Benross turbo head, 9:1, GT1752, TT Intercooler, MegaJolt, BMW M3 leather seats. |
14th May, 2013 at 03:17:56pm
This thread is 4 years old, so I dont rate your chances of a reply ! |
16th May, 2013 at 01:32:45pm
Sorry didn't realise due to sim_ou_nao's recent comment. 1994 Mini Mayfair, 1330, Mspd Ph2 cam, Benross turbo head, 9:1, GT1752, TT Intercooler, MegaJolt, BMW M3 leather seats. |
16th May, 2013 at 03:03:43pm
Im impressed he managed to hold 15psi for 5 mins Edited by Brett on 16th May, 2013. Yes i moved to the darkside |
16th May, 2013 at 03:57:23pm
well said brett , 6 psi for 5 mins is wipers up the screen 6700 rpm in top madness on mine ,15 psi wold just be rev limiter for ages lol. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
16th May, 2013 at 04:04:40pm
Doesn't say he held 15psi for 5 minites does it If something is worth doing, it's worth doing half of. |
16th May, 2013 at 05:00:32pm
All i know i could accelerate 0-160kmh without water and still have iats lower than that and i doubt i would be on the gas much more than 15seconds
17th May, 2013 at 07:03:13am
Brett, that's interesting. So, for a daily driver that doesn't really see above 50 that often, is an intercooler still worthwhile?
17th May, 2013 at 07:23:19am
An intercooler is always worthwhile mate but if you not seeing above 50mph I doubt you will be boosting all over,
Edited by Brett on 17th May, 2013. Yes i moved to the darkside |
87 Posts Member #: 10069 Advanced Member |
20th Jun, 2013 at 12:00:58pm
ooooooh i just bought a tt intercooler today, and noticed your post, do you have any pics of the install, i'm interested your pipe work, (on the car only |
20th Jun, 2013 at 12:18:24pm
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=294956 |
