| Home > Help Needed / General Tech Chat > quick one i hope - an electrical issue. FIXED, cheers gents | |||||||
![]() 1252 Posts Member #: 1656 Post Whore stoke-on-trent |
25th Jun, 2009 at 08:05:34pm
I installed my new dash system yesterday. The rev counter and temp guages work well, but I have lost my indicators. they worked with the standard dash in place. Do I need to connect up the voltage stabiliser or bypass the hazard switch or something?
Edited by stefaz on 27th Jun, 2009. On 23rd Oct, 2009 sim_ou_nao said:
eu gosto de mamas = i like boobs |
![]() 460 Posts Member #: 843 Senior Member Stoke-on-Trent. Duck. |
25th Jun, 2009 at 08:40:23pm
Uh-oh. I'm a bit worried by this Stefaz. I'm counting on electrical your help when I get round to Megajolting my Mini, lol!
Edited by Pottsy on 25th Jun, 2009. |
25th Jun, 2009 at 08:59:33pm
Depends on the year.
25th Jun, 2009 at 09:12:47pm
ok cool. i will double check its earthed properly tomorrow night or saturday. although the only thing I have changed is the wiring to the clocks.
25th Jun, 2009 at 09:17:35pm
Dead easy to knock the earth loose. Did it myself when I had the dash out of my clubman. On 11th Feb, 2015 robert said:
25th Jun, 2009 at 09:18:52pm
Hi
25th Jun, 2009 at 09:20:03pm
no the hazard switch is still there - going now to check if the hazards work..... On 23rd Oct, 2009 sim_ou_nao said:
25th Jun, 2009 at 09:22:36pm
ok the hazards definitely work, but the indicators dont...hmmmm On 23rd Oct, 2009 sim_ou_nao said:
25th Jun, 2009 at 10:07:42pm
Hi
25th Jun, 2009 at 10:10:30pm
Righto I will grab a test light in a little bit and see. If I don't have a feed where is the first place I need to be looking? On 23rd Oct, 2009 sim_ou_nao said:
25th Jun, 2009 at 10:27:15pm
Hi
25th Jun, 2009 at 10:28:48pm
fusebox is brand new...but will double check it as well. On 23rd Oct, 2009 sim_ou_nao said:
25th Jun, 2009 at 10:29:02pm
26th Jun, 2009 at 02:28:43pm
Change the hazard switch.
Own the day
26th Jun, 2009 at 02:31:10pm
Yes you are correct because the hazzard circuit has to handle twice the current. Plus on switching on your hazzard lights you electicaly disconnect the power supply to the indicator stalks.
On 25th Jun, 2009 Pottsy said:
Uh-oh. I'm a bit worried by this Stefaz. I'm counting on electrical your help when I get round to Megajolting my Mini, lol! From memory I think the hazards and indicators actually use different flasher units though? But if they worked previously I'm not sure why they wouldn't work now if you've picked up the "old dash" connections [wiring]? Own the day
26th Jun, 2009 at 02:36:23pm
The hazzard switch is not earthed by the flasher unit! the flasher unit is between the hazzard switch and the fuse. the hazzard switch completes the circuit and the earth is completed through the light bulbs.
On 25th Jun, 2009 apbellamy said:
Depends on the year. You get power to the hazard switch and the stalks, the power gets pushed to either left, right or both sides depending on the position of the stalk and the hazard switch. The hazard switch is earthed by the flasher unit, either behind the clocks or under the bonnett. That is unless you have a MK1, 2 or pre 76 clubman where there are no hazzards. They just work by witch craft! EDIT: corrected earth bit... Might still be wrong though... Own the day
26th Jun, 2009 at 04:32:23pm
26th Jun, 2009 at 09:04:55pm
I think I get the message about changing the hazard switch. i'll try another one tomorrow lol On 23rd Oct, 2009 sim_ou_nao said:
27th Jun, 2009 at 01:19:51pm
All sorted now gents. was a dodgy hazard switch. wacked a new one in and they worked straight away. good times :) On 23rd Oct, 2009 sim_ou_nao said:
