| Home > General Chat > Coil over suspension. | |||||||
365 Posts Member #: 1211 Senior Member Working up the BHP ladder. |
7th Jul, 2009 at 09:17:45am
I've read different things about these. Do we think they are a worth while Upgrade for fast road/ track day use?
7th Jul, 2009 at 10:43:33am
I have them on the back and they are great! They are stiff but dont smash your skeleton! They dontlike with massive pot holes mind! I hit one the other day and the car bounced into the air. General Driving over decentish roads and they seem fine! Ill be fitting them to the front as soon as i can afford em! 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
7th Jul, 2009 at 11:25:58am
7th Jul, 2009 at 11:37:50am
I'm sure on a track or smooth surface both have there advantages but in the real world the Spring coil-over does sound more progressive and so surely should handle better on a rougher surface. |
7th Jul, 2009 at 01:28:55pm
Are we talking about the coil spring upgrade for the cones or your a typical modern day set-up? Own the day
7th Jul, 2009 at 01:43:50pm
coilovers are not the same as a coil spring conversion |
7th Jul, 2009 at 02:44:49pm
Sorry i am refering to a modern day Coil-over setup. i.e. the spring around the damper. |
![]() 453 Posts Member #: 6449 Senior Member Brisbane, Australia |
7th Jul, 2009 at 03:46:40pm
You would have to brace the suspension mounting on the rear. A bar between the 2 mounts in the boot fixes it, but the fuel tank gets in the way. Anyone else have any other solutions? In boost we trust |
![]() 667 Posts Member #: 5232 Post Whore basingstoke |
7th Jul, 2009 at 09:28:53pm
Im running coilovers all round on mine, and I've found the ride is much better than my old cone setup, without loosing any of the handling characteristics or mini feel.
Edited by Prawn on 7th Jul, 2009. Mr. Prawn, the friendly Crustacean- slowly making steps towards forced induction. |
![]() 1105 Posts Member #: 1504 Post Whore Westbury, Wiltshire |
7th Jul, 2009 at 10:39:46pm
Nice Job Prawn.
8th Jul, 2009 at 01:08:09am
I know the difference but some do make the understandable miss interpritation so ill save the rant for the appropriate thread On 7th Jul, 2009 miniminor63 said:
coilovers are not the same as a coil spring conversion Edited by Mr Joshua on 8th Jul, 2009. Own the day
8th Jul, 2009 at 09:12:41am
Aha cheers for that prawn. Your project looks great aswell mate. Looks like lots of nice work carried out very professionally.
628 Posts Member #: 1064 Formally Whyte_ben Horndean, Hampshire |
8th Jul, 2009 at 11:09:50am
I think im going to have to do the same. I cant quite get it as low as I want without the subby hitting the mount.
A friend ran into a problem with his coil over set-up, he had to modify the front subframe turrets to give the strut more clearance because it was hitting the subframe during its travel. He also had to fabricate new lower brackets for the front top arms to supplement his subframe mod. On 7th Jul, 2009 miniminor63 said: coilovers are not the same as a coil spring conversion
10th Jul, 2009 at 01:33:09am
Just a thought but there are two lengths of coilovers to cater for standard ride height and lowered.
10th Jul, 2009 at 07:39:59am
Give me a shout if you've got the car at work. Isambard Kingdom Brunel said:
10th Jul, 2009 at 07:41:05am
Cheers guys,
10th Jul, 2009 at 10:38:03am
Sorry my post was a little missleading the actual shock was hitting the subframe. Own the day
10th Jul, 2009 at 11:24:57am
ah right. Perhaps some redesigned lower mounts would mount the shock further outboard to solve that problem? Mr. Prawn, the friendly Crustacean- slowly making steps towards forced induction. |
10th Jul, 2009 at 11:29:53am
He also had to fabricate new lower brackets for the front top arms to supplement his subframe mod. Own the day
11th Jul, 2009 at 11:27:56pm
Gents.
On 10th Jul, 2009 turbominivanman said:
Just a thought but there are two lengths of coilovers to cater for standard ride height and lowered. My previous Spax coilovers smacked the crap out of the back suspension and I think its because I bought standard ride height coilovers in error when I should have bought lowered ones. My car is on 10's and could be considered low so its probably with good reason why I suffered what sounded like the dampers bottoming out over large bumps. I've just finished fitting the GAZ replacements to avoid the effect and the literature definitely says they're lowered jobs so when I take it back out on the raod I'm hoping to have cured the banging noise over large potholes. Will report tomorrow, weather permitting. Have now given the van a good workout with the new rear shocks. The lowered rear GAZ coilovers have completely eliminated my rear suspension banging / bottoming suffered with the previous Spax units, believed to be standard ride height jobs purchased in error. It's good news - and now a pleasure to drive. Each GAZ unit has 43 click adjustments on the hydraulic damper - I've got mine on the 18th click and the car's transformed. This is with 1.9 in ID progressive rate 80/125 lb springs and the beam adjusted to 0.5 deg negative rear camber and 3.2 mm toe-in. edit: 0.5 degrees negative camber, NOT positive. Cheers. Richard. Edited by turbominivanman on 11th Jul, 2009. Minivanless, but reluctantly happy living with the decision. There'll be another one day.
11th Jul, 2009 at 11:30:55pm
Those other shocks may require revalving as bottoming out can (in extreme instances) cause impact damage to the valve. Own the day
11th Jul, 2009 at 11:35:06pm
Good point but they've only done about 800 miles in the last 12 months.
12th Jul, 2009 at 12:24:12pm
What dampers do people usually run with 13s? The lowered coilovers or the standard height ones?
In boost we trust |
