| Home > Help Needed / General Tech Chat > megajolt problems | |||||||
6 Posts Member #: 6593 Junior Member south manchester |
8th Jul, 2009 at 11:41:03pm
hi all
Edited by AlexF2003 on 9th Jul, 2009. DrX rides again...... |
2646 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
8th Jul, 2009 at 11:47:32pm
Trigger wheel missing tooth in correct position in relation to VR? Is the VR polarity correct? Do you know if the ford parts are servicable, and actually work? Are you sure its a fault with the MJ not fuel related?
8th Jul, 2009 at 11:54:45pm
i cant even get it to run just on the edis unit but it sparks and there is fuel i have tried leads every which way! DrX rides again...... |
9th Jul, 2009 at 12:02:18am
9th Jul, 2009 at 07:57:59am
i was running it on the dizzy and went on the london 2 brighton run and the dizzy packed up so i have put this megajolt on and i have not been able to start it since installation???????? DrX rides again...... |
9th Jul, 2009 at 08:03:49am
I think that we have established that you have problems. The main one being that you can't use a forum. Stop posting the same question. http://www.twin-turbo.co.uk
9th Jul, 2009 at 08:10:21am
so it broke down, which you assummed was the dizzy. So you fitted megajolt in a hope of fixing it and it still doesn't run.
9th Jul, 2009 at 09:52:29am
and what map do you have |
9th Jul, 2009 at 08:24:41pm
ive got it started thanx to u lot! it was the timing DrX rides again...... |
