Home > General Chat > Pic Request
1293 sprite
Member #: 5449
Melton Mowbray
I've got a 2wd (I think) cosworth intercooler, but I'm struggling to route the pipework around the servo. I'd like to keep the servo.
Has anyone got any pics of their cossie intercooler setups preferably with servo please?
Thanks,
James
1293 88.8hp 82.2ftlb
17.3 1/4 @ 78 mph
Naturally Aspirated (for now)
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=237690
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=137698
1293 sprite
Member #: 5449
Melton Mowbray
Thanks for the links *happy*
The closest ive got so far is this
The only problem is the bonnet sits quite high because of the pipe on the left over the servo. Its going to be raised at the back anyway, but its still a bit too high...
EDIT : Useing a "Nic" Plenum, so that should help with the pipework...
Edited by 1293 sprite on 3rd Sep, 2009.
17.3 1/4 @ 78 mph
stefaz
Member #: 1656
stoke-on-trent
http://www.turbominis.co.uk/forums/index.p...id=171785&fr=25
I'm going to update that soon with some pics of how the bonnet sits. just need to get home before it gets dark for a change
Edited by stefaz on 3rd Sep, 2009.
Dicanio
Member #: 91
http://www.turbominis.co.uk/forums/index.p...&tid=9373&fr=75
Go to page 4.
But I've got a plenum from Nic, which helps.
1293 sprite
Member #: 5449
Melton Mowbray
Thanks for the links :)
They all look like tidy installs.
Mine looks similar to yours stefaz with the pipes over the top of the servo. Just need to get the engine back in to see if they will all link up ok.
Also Dicanio I've got one of Nic's plenums too, when it arrives *wink*
17.3 1/4 @ 78 mph
n.g.l.
Member #: 181
Chard, Somerset
I was just about to say go under the servo!
t3gav
Member #: 229
Gavin@minispares.com
kent
On mine i'm pretty sure i can do as mike suggests, similar to ngl's setup but the pipe on the left goes straight forward under the braided brake pipe hoses, i dont have a standard breather though.
I found it impossibel to get the cosworth one in and terail all the original bits (servo, cold air intake etc.)
So I chucked it my brothers way and stuck in am S2 Escort RS one. Much easier and bigenough for dectent power/cooling.
t3gav
Member #: 229
kent
Ah courtesy of theoneeyedlizard, hope you dont mind http://www.turbominis.co.uk/photo/658/
1293 sprite
Member #: 5449
Melton Mowbray
Thank you for all your help, pics and links.
17.3 1/4 @ 78 mph
That's not a cossie cooler in that pic, but it may help with the pipework around the servo.
TurboMike1992
Member #: 9928
Hartley, Kent
my setup using a phase 2 escort rs turbo cooler iirc
Low boosting for now.
