Home > General Chat > inner and outer sills with floor, one panel!!!
MONSTER HEDGEHOG
Member #: 4340
sideways, Birmingham
i droped a few bits down to old skool minis the other day and got chating with paul, he does a compleate half floor with inner sill and a outer sill spoted on as one whole panal... for £90.
its been a while since ive been to a show so can you get these everywhere or is he the only guy that does them? *surprised*
On 15th Dec, 2009 fastcarl said:
sell the lot to me for £70 pounds and i'll let you stand on the outside edge and look on my inner circle of closest frinds, lol
carl
FOR EVERY WELL THOUGHT OUT AND WELL EXECUTED PRICISION JOB EVER CONCIEVED, YOU CAN GUARANTEE THAT SOMEWHERE IN WALSALL OR THE BLACK COUNTRY THERE WILL BE A BLOKE TRYING TO ACHIVE THE SAME BY MEANS OF "ITIN IT WI LUMP AMAR"
Oli put one on his estate rescently. Think it came from Somerford.
MONSTER HEDGEHOG
Member #: 4340
fair enough, it seems a dam good idea compared to messing about with 30yr old inner sills and floors ect
carl
DSN do as well although I can't remember (when I looked at a year ago) if they have the outer sill spotted on, but it was certainly a full length, half width floor section.
90 quid?
i thoiught they were a few hundred.
rosco454
Member #: 5222
Northumberland
Heritage produce this panel as i priced it up a while ago.apbellamy is right,somerford do stock it although their delivery is quite expensive on them.
rosco454
Member #: 5222
Northumberland
Had a quick look on the bmh website and this is the full lot up to the tunnel;
ADA36002RH
ADA36002LH
£134.26 each
They also do a smaller version up to the first flute in the floor;
ADA36002RQ
ADA36002LQ
£100.59 each
Edited by rosco454 on 17th Sep, 2009.
ahhhhhh,
i missed where you said "half" floor
The DSN ones are just under £50 (but add VAT) for a half floor, ie, PNL3195 and PNL3196
I looked at them about a year ago when I was in there and the pressings looked quite good. Obviously what they look like and how they fit are two different things.......
Oli
Member #: 1910
Wilts
Have a look in my build thread. Mine cost 80 odd squids.
It was bloody fiddly to fit, but you get there in the end.
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=301546
Ive allways had bits from mini machine (darlington).
They will spot weld any combination for you to spec,
eg ,inner outer sill inc doorstep or floor be it full or half.
supose it makes life easyer for the diyer.
Rick
MONSTER HEDGEHOG
Member #: 4340
this is usefull info, the old skool panals seem to be good pressings and ive seen a few of the cars thayve done with them on and thay look good. im almost tempted to drop some on my clubby just for piece of mind.
carl
