| Home > Help Needed / General Tech Chat > 1st motion bearing removal problems | |||||||
23rd Sep, 2009 at 11:06:47pm
hi, im rebuilding a fast road engine for my mpi cooper.
23rd Sep, 2009 at 11:17:04pm
have you removed the laygear?
23rd Sep, 2009 at 11:33:31pm
yes, laygear removed. removing the bearing is the last part hopefully before i can start to put back together. |
23rd Sep, 2009 at 11:39:49pm
Should come out ok then,
23rd Sep, 2009 at 11:43:23pm
You got the big circlip yes??
Edited by Turbo Tel on 23rd Sep, 2009. website:- http://www.terryhunt.co.uk
23rd Sep, 2009 at 11:57:01pm
yes, circlip removed. will have another go again tomorrow. it just doesnt seem to want to come. got to a point where i could hardly move the nut on the puller (using long power bar). will have a closer look tomorrow in daylight |
24th Sep, 2009 at 03:29:27am
How were you using a puller, ie, against what ???
24th Sep, 2009 at 04:28:36am
On 24th Sep, 2009 Rod S said:
How were you using a puller, ie, against what ??? I can't visualise how you could use a puller.... Thats a good point.. A conventional puller would just be trying to rip the nose bearing off the shaft.. website:- http://www.terryhunt.co.uk
24th Sep, 2009 at 04:58:26am
the best way is a long punch on the top part of the outer race, but you must also give the tail of the shaft a tap so it comes out square. other wise you will be trying to make the hole bigger and you dont want that.
24th Sep, 2009 at 01:22:08pm
That guessworks guy is clearly a very helpfull type, posting useful guides and the like, but he sure doesn't like cleaning stuff very well before re-assembling it.
24th Sep, 2009 at 08:25:54pm
cheers for reply, dont know what i was trying to do last night, was over tired!
24th Sep, 2009 at 08:56:22pm
hmmmm,
24th Sep, 2009 at 09:49:00pm
will make sure i dont. just hope mine arent lost or gone with someone elses engine. i would not be happy. they have a good reputation for engine work, hopefully they are just to one sude up there somewhere.
