Home > Show Us Yours! > 1380 supercharged build
mikemph
Member #: 449
Oxford
Well after some deliberation and after sripping down 3x A+ 1275 I took a section of the best bits to build a 1380 SC
So far the block is over at rob walker in witney with a set of 73.5mm cast omega 11cc dish being bored out next week and the centre cap machine for a strap.
I have a box of bits from MED
Oil Pump
Bearings
SC drop gears
Gaskets
Followers
MG metty Cam
Std Unleaded head
1 turbo verto, 1 from unknown
AP rally/race plate
Alloy duplex
Cetral oil pick up
1 very good low mileage Gbox
So the fun begins I will copy roberts verto clutch set up over the weekend. Might even make a steel flywheel if there is any steel big enough at work.
I will get some pics up soon as I get some work done.
Need to get cracking on the head over the weekend open up the chambers and ports
I also get moking up the manifold for SC.
All of this depends on how much work I have to do at work hopefully it will be quiet and I can get on with the above.
I will update as I go
Edited by mikemph on 25th Sep, 2009.
EssexSteve
Member #: 7029
Wickford Essex
pics and more pics please
mikemph
Member #: 449
Oxford
the build is continued from this link http://www.turbominis.co.uk/forums/index.php?p=vt&tid=314506
mikemph
Member #: 449
Oxford
well sorry for the long time since the update.
Engine is all built and in the car... running and kinda idling with the MS. So I am hoping I could find someone else with a rough timing map. I have tried andy500 but no reply.
I will get some pics up later on today hopefully
Andy500
Member #: 2443
Cheshire
Sh1t sorry about that mate, i completely forgot. It would probably be best if you download the m3dk software for free from emerald...www.emeraldm3d.com and then i will send a copy of my map and you can scan through it all then.
Andy
mikemph
Member #: 449
Oxford
I am pretty sure I have a copy of the software... think it came with a haynes tech manual on some kind of efi tuning manual.
Anyway that would be great if you could send me a copy over, just want to gett it somewhere close.
It idles pretty well now, and will start after about 3 trys of coughing from cold.
Right time to dig out some pics
mikemph
Member #: 449
Oxford
i think youll have to adjust that plug gap mike ? *wink*
nice head mike,
dont wanna slip and grind those seats....
got any old valve's you could fit?
mikemph
Member #: 449
Oxford
The plug only needs a gentle tap on the end and the gap will be just right *wink*
Yeah I dropped in an old set of valve when grinding.
mikemph
Member #: 449
Oxford
Here is the latest, I have got it all up and running but needs some time spent road mapping
This is first couple of goes at getting it running
Here is after a few hours of playing
pinkyandnobrain
Member #: 2588
Pretoria South Africa
Sounds good !
"Try to take over the world!"
