| Home > Help Needed / General Tech Chat > New or Old loom?! | |||||||
628 Posts Member #: 1064 Formally Whyte_ben Horndean, Hampshire |
30th Sep, 2009 at 02:39:39pm
Alright guys,
30th Sep, 2009 at 02:43:53pm
If I remember correctly, your car is the ridiculously smart blue one, I'd be tempted to buy a new loom, that way it will all look smart and fresh and not have 20 years or so of grime on it.
30th Sep, 2009 at 02:44:24pm
Do you have the original loom or are you starting from scratch? If you don't have a loom then you would probably find it difficult to get connectors for headlights, dash switches etc. I am actually in the same situation as you but I have a donor loom so I am going to modify that as I can't afford a new loom and then start cutting it up On 12th Nov, 2009 Paul S said:
Gary's description is best |
30th Sep, 2009 at 03:05:33pm
Most of the connectors are easy, but things like stalks and switches you'll need a donor loom for.
![]() 453 Posts Member #: 6449 Senior Member Brisbane, Australia |
30th Sep, 2009 at 03:17:26pm
Not that relevant to your case, but im in a similar problem. Im going to be running a toyota engine, so have got to make a working loom out of a starlet. I think ill either get a loom custom made or convert the starlet one to fit in a mini. In boost we trust |
30th Sep, 2009 at 03:46:45pm
Do you mean old style as in 4 fuse box and very simple or late loom with every imagiable relay switch and module built in. Or by old do you mean second hand? Own the day
30th Sep, 2009 at 03:48:06pm
I would call autosparks, tell them you have a miniclubman, and want a custom loom, and have them build it for you.
30th Sep, 2009 at 04:46:14pm
Ahh ok thanks guys,
On 30th Sep, 2009 Mr Joshua said:
Do you mean old style as in 4 fuse box and very simple or late loom with every imagiable relay switch and module built in. Or by old do you mean second hand? I mean old as in second hand Mr Joshua.
30th Sep, 2009 at 04:55:46pm
30th Sep, 2009 at 11:39:11pm
Ive been lucky enough to find somone to make me a custom loom for mine, but im keeping it as simple as poss.
1st Oct, 2009 at 12:45:58pm
Unless you know exactly how the wires are configured in one I would get one of the shelf as they can hide many faults that are hard to track down. Own the day
