Home > General Chat > seam welded and lightened front subframe
jamz
Member #: 2292
Tool
Herne Bay, kent
is it worth doing if so where abouts needs welding and where can you lighting it. i have found out that i have a friends who is actually a very good welded. any pictures and info will be greatly appriciated
also after that how much would i be looking do you thinkg to get it powder coated or shall i jsut paint it my self?
cant beat a good blowout.
have a quick search about lightening the subframe mate there is some brilliant pics some where, and i think most of the higher powered boys have seemed the subby or running a tubular one lol
mainly the seems needed are round the towers, if you look at a bare subframe the places needed to be welder should be obvious
jamz
Member #: 2292
Tool
Herne Bay, kent
i tried searching first but it came up with an error and still is.
Put a seam weld on all the joints and brace the bottom tie bar mountings.
This is my old lightened one, its nearly 3kgs lighter
You need a very friendly MOT man though
Paul
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=161098
there is others there honest,
i think your using a too specific search term, try just 'subframe' and go from there!!!
edit: paul your probably the best person to ask doesnt all the holes weaken the frame? top farame aswell btw8-)
Edited by Brett on 7th Oct, 2009.
like it paul.
Oli
Member #: 1910
Wilts
has anybody got any pictues of the tie bar mount strengthened?
AS i need to do mine, i have a thought what to do, but would like to see others.
have a look at Rod S' build thread
im down in london at the mo, but ill post up some pics of mine when im on my home pc, i just gussetted bother sides of the tie bar mount with traingles about 4" long and 2" wide
Oli
Member #: 1910
Wilts
Cheers Ap and joey, i think im on the same wave length as everyone else.
found the old thread, but putfile has gone tits up, ill fix the links when im back
http://www.turbominis.co.uk/forums/index.p...id=174403&fr=25
andywaller
Member #: 1826
Maldon Essex
I just welded a small triangle to strengthen the tie rod between the main frame and the boss.
Oli
Member #: 1910
Wilts
I see... right i get it now lol, if you could fix them when your back oey that would be very much appreciated!
ill fix the links in the other thread now oli
