| Home > Help Needed / General Tech Chat > custom turbo manifold | |||||||
100 Posts Member #: 7614 Advanced Member Malaysia |
30th Nov, 2009 at 08:54:56am
hi guys
http://www.minimonstermotorsport.blogspot.com/
30th Nov, 2009 at 11:39:29am
anyone? http://www.minimonstermotorsport.blogspot.com/
![]() 453 Posts Member #: 6449 Senior Member Brisbane, Australia |
30th Nov, 2009 at 12:06:42pm
Your best bet would be to import a metro turbo engine complete from the uk and work from there. That way you have a whole engine to improve in the same way everyone does on this forum. Its a far simpler option that buying/fabricating all of the parts you will need. In boost we trust |
30th Nov, 2009 at 12:22:20pm
but the currency is killing me!
30th Nov, 2009 at 12:27:49pm
Mirage has a T2/T25 flange whereas a metro turbo manifold has a T3 flange. The metro manifold can be made work with a T2 flange if an adapter plate is used though.
Gary's description is best |
30th Nov, 2009 at 12:31:56pm
gary,
30th Nov, 2009 at 12:39:14pm
Get the welder out. You could get the turbo flange and bends off ebay. You would probably have to make the head flanges as I don't think they are available on ebay. On 12th Nov, 2009 Paul S said:
30th Nov, 2009 at 12:39:32pm
Sorry, didnt read your other post about how many minis you had and how modified they were. You wont need to do what i said, you have the gear already. In boost we trust |
30th Nov, 2009 at 12:49:37pm
I think your options are:
30th Nov, 2009 at 12:53:05pm
ok.
30th Nov, 2009 at 01:10:22pm
There is no real info on what manifolds work best on simaese ports. On paper, the Mirage looks like it would be useless but alot of people make amazing power with it. Also, Robert makes great figures with his metro manifold. Paul S is trying an over the clutch manifold. Benjamin has a big bore custom job and I dicked about with narrow pipes and different entry angles. No back to back tests though On 12th Nov, 2009 Paul S said:
30th Nov, 2009 at 03:46:17pm
On 30th Nov, 2009 minimonster said:
ok. the best solution is to use standard manifold. but if i cant get hold to it, and the only solution is to custom made it, how the bend would look like? the pipe length,etc? Basically fit in what you can Search the names Gary has given you and look at what they have done Edited by Nic on 30th Nov, 2009. |
1st Dec, 2009 at 12:33:00am
isee
On 30th Nov, 2009 GaryOS said:
There is no real info on what manifolds work best on simaese ports. On paper, the Mirage looks like it would be useless but alot of people make amazing power with it. Also, Robert makes great figures with his metro manifold. Paul S is trying an over the clutch manifold. Benjamin has a big bore custom job and I dicked about with narrow pipes and different entry angles. No back to back tests though http://www.minimonstermotorsport.blogspot.com/
1st Dec, 2009 at 08:31:29am
On 1st Dec, 2009 minimonster said:
isee but i'm more interested towards the janspeed conversion manifold. the turbo sits atop the clutch housing,so the bulkhead didnt need modifying.is it true? also,if custom the manifold,wat is the pipe size,i mean the thickness of the pipe is the best for the job? On 30th Nov, 2009 GaryOS said: There is no real info on what manifolds work best on simaese ports. On paper, the Mirage looks like it would be useless but alot of people make amazing power with it. Also, Robert makes great figures with his metro manifold. Paul S is trying an over the clutch manifold. Benjamin has a big bore custom job and I dicked about with narrow pipes and different entry angles. No back to back tests though On 11th Feb, 2015 robert said:
1st Dec, 2009 at 12:05:07pm
thanks
1st Dec, 2009 at 12:11:28pm
i want to run TD04 turbo. does anyone know any pros&cons of this turbo? It depends on which TD04 as there are several different versions. I reckon the TD04 from the Saab 95 might be a good contender for a high boost 1275+ but would have to see a compressor map first. If something is worth doing, it's worth doing half of. |
1st Dec, 2009 at 12:41:13pm
this is what on the turbine
1st Dec, 2009 at 09:38:58pm
2nd Dec, 2009 at 12:10:18am
i think it is maybe from Mitsu GSR 1.8T and also from Mitsu Mirage 4G61T..
On 1st Dec, 2009 mini13 said:
mitsubishi colt? http://www.minimonstermotorsport.blogspot.com/
2nd Dec, 2009 at 05:23:39am
this is the pic of the turbo
2nd Dec, 2009 at 08:33:33am
that looks big... Yes i moved to the darkside |
2nd Dec, 2009 at 10:27:18am
What is the A.R number on the turbine housing on that?
2nd Dec, 2009 at 11:19:18am
err...
2nd Dec, 2009 at 11:48:45am
Read the turbotech over on Garrett if you're having difficulty dealing with the basics. A/R should be a number stamped on the housing (<1) On 12th Nov, 2009 Paul S said:
2nd Dec, 2009 at 11:51:41am
thanks Gary..
