| Home > Show Us Yours! > piston damage | |||||||
614 Posts Member #: 2153 Post Whore kings langley |
20th Dec, 2009 at 01:05:46am
280 Posts Member #: 4340 Senior Member sideways, Birmingham |
20th Dec, 2009 at 01:37:17am
are the trusts knacked to the point of resembling blue shrapnal? im just wondering where that damage came from
On 15th Dec, 2009 fastcarl said:
sell the lot to me for £70 pounds and i'll let you stand on the outside edge and look on my inner circle of closest frinds, lol carl FOR EVERY WELL THOUGHT OUT AND WELL EXECUTED PRICISION JOB EVER CONCIEVED, YOU CAN GUARANTEE THAT SOMEWHERE IN WALSALL OR THE BLACK COUNTRY THERE WILL BE A BLOKE TRYING TO ACHIVE THE SAME BY MEANS OF "ITIN IT WI LUMP AMAR" |
20th Dec, 2009 at 10:14:45am
Check the thust faces on the crank too. Mine were trashed.
In the 13's at last!.. Just |
20th Dec, 2009 at 11:39:01am
your engine has had some bongo!
20th Dec, 2009 at 01:12:27pm
yes i have found tiny slithers of thrust bearing stuck to the underside of the piston crown. well and truley fooked! the crank looks to have survived its not got any hot marks on it or scoring...
20th Dec, 2009 at 01:26:13pm
Id try dressing it up first as long as the ring slot hasnt closed up
I seriously doubt it! |
20th Dec, 2009 at 07:06:22pm
im guessing your running a grey or orange clutch cover, id oil feed the thrusts as its so simple to do. if your not confident then get force to do it. at my mates mini garage he had 2 minis a month coming in with dead thrusts due to heavy clutches
22nd Dec, 2009 at 12:39:59am
hi emailed med turns out they dont do forged pistons in 10cc dish +020 so thats interesting, are there any guides as to how to oil feed the thrusts?
22nd Dec, 2009 at 01:16:09am
yep, fastcarl invented this back in 1742 AD
22nd Dec, 2009 at 01:19:31am
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=218790 "Turbo's make torque, and torque makes fun"
![]() 2054 Posts Member #: 452 Post Whore Chester, UK |
22nd Dec, 2009 at 10:35:31am
bit of a shitter if they ain't forged as it was sold with forged pistons. |
998 Posts Member #: 2178 Post Whore Leyland, Lancs |
22nd Dec, 2009 at 10:53:41am
Looks like they've changed them - they are listed as a 6.5cc dish on the MED website, but it looks like an offset dish. I'm sure they used to do a 10cc forged piston. On 15th Jul, 2009 fastcarl said:
a breif struggle ensued but Will emerged the victor with a pair of undies in his possesion On 21st Sep, 2009 apbellamy said:
No, but you did chuck your guts up over my front gate the Saturday before! You even managed to get a bit in your arm pit... |
![]() 3756 Posts Member #: 1709 I like granny porn. LONDONSHIRE |
23rd Dec, 2009 at 09:15:40am
12cc??i know they make an 18cc On 2nd Oct, 2009 Vegard said:
I bet my first wank came quicker than your first mini turbo These new modern turbos with their quick spool up time, would make the competition harder. On 15th Aug, 2011 robert said:
phew!!! thank you brett for smashing in my back doors .( not something i imagined writing... EVER) |
23rd Dec, 2009 at 10:33:17am
As far a I know, old Omegas were 10cc. Now you can get a 6.5 offset or not and the 18cc of course. How do I know? I've got them all On 13th Jul, 2012 Ben H said:
23rd Dec, 2009 at 05:37:11pm
so the question now is... do i use it again or not? :) anyway going to local engineers in new year armed with pictures to see if they will do the thrust mods... then i'l re asess the budget for pistons
23rd Dec, 2009 at 06:40:58pm
If the top ring slot hasnt been damaged Id use it I seriously doubt it! |
23rd Dec, 2009 at 07:17:06pm
thanks for the advise paul i bought a tiny file set today to dress it will post pics when i'm happy, see what you guys think... Top ring slot has survived by the looks of things :) Speeding is like masturbating, everyone does it, but not all of us film it and put it on the internet
24th Dec, 2009 at 09:49:30am
be Assured! in my experience, if you reuse that piston it will fail in the ring lands in a short time ........... sorry to be a doubter or pi** on you parade
24th Dec, 2009 at 10:07:35am
I stand corrected, go with the above advice
![]() 136 Posts Member #: 5193 Advanced Member Dunstable |
24th Dec, 2009 at 10:15:03am
i have the same on my engine that i took to med and he said the ring lands would eventually let go |
24th Dec, 2009 at 10:32:14am
On 24th Dec, 2009 munnracing said:
i have the same on my engine that i took to med and he said the ring lands would eventually let go would this be at the same time as he tried to sell you some replacements,lol. the piston damage looks like dry scuff to me , the thrusts have failed allowing the crank to wander and with it the pistons rub on the bore wall when the clutch is depressed, ive reused pistons that looked like this with no lasting effects once fettled up, as long as the ring groove is undamaged , do not put a file into the ring groove , if new rings dont slot in the pistons are fininshed . carl carl |
24th Dec, 2009 at 10:32:39am
for the sake of a piston are you happy to risk the whole block?
AlexF |
24th Dec, 2009 at 10:48:54am
The piston has overheated to the point that it has expanded and partialy siezed in the bore. This is most likely down to over advanced ignition, and it has not nescisarally suffered detonation. over advanced ignition is basicaly compressing an already hot and expanding gas, and when you compress a gas it heats up. The piston expands more along the pins because there is more metal in that region, so the hotter you get it, the more it expands.
24th Dec, 2009 at 10:56:31am
As above ^^^Ive used pistons in similar condition with no prblems. I'd re-use it. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
24th Dec, 2009 at 11:17:14am
I would agree with Carl, spocket and Matt I have seen the exact same marking on a piston I took from a race engine where trusts had failed. I dressed refitted it and have had no problams to date. On 17th Feb, 2009 Rob H said:
