| Home > Help Needed / General Tech Chat > plenum 'ram insert' needed or not? | |||||||
![]() 61 Posts Member #: 7857 Advanced Member NAILSEA, near bristol |
13th Jan, 2010 at 04:36:14pm
just a quicky, can anybody tell me why the plenum has the ram inset fitted (its quite restrictive of flow or am i wrong?) ive removed it as im modifying it, and notice there is already a ram-type stub-stack already cast into the SU flange on the inside.
13th Jan, 2010 at 04:39:34pm
do you mean the restrictor?
13th Jan, 2010 at 04:41:38pm
you need the restrictor ring in there no ifs or buts with a carb set up
13th Jan, 2010 at 04:47:57pm
thanks for the quick responce. back to the drawing board... |
13th Jan, 2010 at 04:52:54pm
Why are you trying to modify it? https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
13th Jan, 2010 at 05:11:39pm
On 13th Jan, 2010 matty said:
Why are you trying to modify it? ive changed the boost-in pipe, and changed the profile of the box'y shape to more of a high-flow barrel type desight (used the metty plenum as a base platform.) |
13th Jan, 2010 at 05:43:45pm
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=513 On 28th Aug, 2011 Kean said:
13th Jan, 2010 at 06:46:55pm
a pitot tube can be used in place fo the restrictor if plumbed in correctly, again ought to come up in a search. turbo 16v k-series 11.9@118.9 :)
13th Jan, 2010 at 06:48:47pm
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=272999 turbo 16v k-series 11.9@118.9 :)
