| Home > Help Needed / General Tech Chat > Rolling onto its side? | |||||||
72 Posts Member #: 5062 Advanced Member Herts |
27th Jan, 2010 at 01:05:46pm
Ok this is a bit of a strange and probably stupidly easy question but i'd still like peoples advice.
27th Jan, 2010 at 01:16:24pm
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=340312
Yes i moved to the darkside |
27th Jan, 2010 at 02:49:04pm
Old tyre on the sill and a carpet on the lip of the roof, just lean the whole thing against a wall. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
27th Jan, 2010 at 02:53:11pm
thanks but i've already read that link, i would like to know HOW you roll the car over?
27th Jan, 2010 at 02:54:54pm
Pure brute strenth! or two people pushing from the lip of the roof then when the sill reaches waste height grap the sill lift it rest of the way.
27th Jan, 2010 at 03:11:27pm
On 27th Jan, 2010 MikeRace said:
Easy. I did it on my own, well I say on my own, in actual fact I got my old mate Basshunter round to help out, he is double hard you know.
27th Jan, 2010 at 03:14:39pm
^ If something is worth doing, it's worth doing half of. |
27th Jan, 2010 at 03:25:12pm
I did mine by myself, several times.....
27th Jan, 2010 at 03:49:09pm
Cheers fella's Edited by Barrythebodger on 27th Jan, 2010. |
27th Jan, 2010 at 07:22:25pm
I saw somebody on another forum with a ratchet strap from the side you would lift on to something solid beyond the other side then just racheted away and over it went. On 11th Feb, 2015 robert said:
27th Jan, 2010 at 07:42:14pm
Long straight, hard right and a bit of hand brake should get it on it's side. Isambard Kingdom Brunel said:
27th Jan, 2010 at 07:59:53pm
followed by it's roof, then the other side etc etc etc On 11th Feb, 2015 robert said:
603 Posts Member #: 1938 Post Whore near Dundee |
27th Jan, 2010 at 08:05:50pm
good idea Rod with the wood cable tied on wood think ill steal that |
27th Jan, 2010 at 08:22:42pm
On 27th Jan, 2010 commander said:
good idea Rod with the wood cable tied on wood think ill steal that Feel free to steal the idea, but you can't steal the wood, I've burnt that since to keep warm
My idea was to be able to roll the shell back onto its base without damaging the sills then be able to drag it across the garage to roll it on the other side. I did end up using steel ties as the nylon cable ties broke quite often.
28th Jan, 2010 at 01:04:11pm
What are the brackets for in the corners of the floor??
28th Jan, 2010 at 03:07:20pm
On 28th Jan, 2010 apbellamy said:
What are the brackets for in the corners of the floor?? Thought I'd best check before I chop mine of |
28th Jan, 2010 at 03:15:08pm
28th Jan, 2010 at 06:34:36pm
Do you mean the ones by the heal board hidden under the sills? If so I'd leave them alone as they help take the load from the rear subframe. Isambard Kingdom Brunel said:
28th Jan, 2010 at 07:40:19pm
No the ones in the floor corners half hidden by over sills (well at one side only now). On 11th Feb, 2015 robert said:
29th Jan, 2010 at 05:04:18pm
Another plug lol!
On 5th Sep, 2011 Vegard said:
