| Home > Introduce Yourself > Bought a Turbo at the weekend... | |||||||
14 Posts Member #: 8145 Member Home/Uni: Halifax/Hatfeld |
1st Feb, 2010 at 11:51:16pm
Hello
![]() 481 Posts Member #: 7893 Senior Member Portsmouth |
2nd Feb, 2010 at 12:04:14am
Hey Ed, not long been on here my self, and am in the same possition as you, just bought a turbo from Joe on here :) doing my first turbo mini and I am taking full advantage of advice and tips on old posts on here, good to search before posting, 90% of my questions I have found on old posts :)
809 Posts Member #: 224 Post Whore Katy TEXAS |
2nd Feb, 2010 at 12:20:08am
Hello and welcome,
499 Posts Member #: 2257 Senior Member Brighton |
2nd Feb, 2010 at 12:39:49am
Hello and welcome mate :)
2nd Feb, 2010 at 07:52:58am
Hello and welcome.
2nd Feb, 2010 at 02:07:13pm
i love those retro 1100 specials, how bad is the damage to the body? "Turbo's make torque, and torque makes fun"
2nd Feb, 2010 at 02:35:19pm
http://www.theminiforum.co.uk/forums/index...ic=60428&st=690
2nd Feb, 2010 at 02:38:24pm
Have a look through the 998 section on here. You might find a T3 a bit on the big side. If something is worth doing, it's worth doing half of. |
2nd Feb, 2010 at 04:49:41pm
I think i will use a T2... although having just bought that one im not sure... i have been speaking to Wil Hamer and he has given me some great advice...
2nd Feb, 2010 at 05:16:37pm
welcome youve come to the right site
2nd Feb, 2010 at 05:20:55pm
On 2nd Feb, 2010 tedmcedd said:
I think i will use a T2... although having just bought that one im not sure... i have been speaking to Wil Hamer and he has given me some great advice... i think new bearings all round will be in order... so far i have been thinking about this spec: T2 on metro manifold RS intercooler 2 core rad 12G 295 (got) metro turbo dizzy or weld mine... regrind the crank lightened/balanced fly possibly lighten/balance the conrods x pin diff and i dont know if i should 1098 or i have a 998 with +20 powermax pistons... thing about the shell is i think the subframe/radius arm have been affected, it was very hairy driving him after the accident... felt odd round the corners.. The standard con-rods will be fine. Use the money to get a Megajolt ignition. Find a decent cam, something like an Mg Metro one would be just fine. Fix the handling first else the torque will put you in the ditch. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
2nd Feb, 2010 at 06:27:23pm
You have probably damaged the radius arm on that side or the pin holding it. Jack and support the car and have a wiggle, if it feels loose then there's your problem.
![]() 497 Posts Member #: 7641 Senior Member Jersey, CI |
2nd Feb, 2010 at 11:02:39pm
Hello and welcome |
3rd Feb, 2010 at 08:01:53am
First, welcome :)
thing about the shell is i think the subframe/radius arm have been affected, it was very hairy driving him after the accident... felt odd round the corners.. Often the bit that bends first is the metal braket between the outer end of the radius arm and the subframe - held on with only four bolts and the large nut on the radius arm pin itself - worth checking first ??? Schrödinger's cat - so which one am I ??? |
3rd Feb, 2010 at 05:56:50pm
cheers guys all great advice
![]() 1596 Posts Member #: 8027 Post Whore Thrapston, Kettering, Northants NN14 |
3rd Feb, 2010 at 06:50:19pm
The bean is gettin turboed :)
I popped my first one out the other day... |
3rd Feb, 2010 at 10:47:03pm
well i was thinking Tundra Green... or teal blue... a 70's colour...get the mk3 brightwork on him, make him a real sleeper...
Good luck with the build...!
