Home > Help Needed / General Tech Chat > Rod bolts fouling gearbox webbing A-series with A+ box
Went to re-assemble my engine last night after a gearbox change and installation of ARP rod bolts.
This is an a-series 1275 mated to an A+ DAM5626 box. The symptoms I have are similar to the thread below that Paul H suffered with the 1100 build.
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=250675
Am I right in thinking that the solution is the same? Dry build with some plastercine or similar, rotate crank to mark where it catches, disassemble, file webbing down, repeat until no catching?
