| Home > General Chat > piston / bore clearance | |||||||
24th Feb, 2010 at 03:52:50pm
im having a 3 way conversation here but just want to run it past you lot before committing to anything
Yes i moved to the darkside |
24th Feb, 2010 at 04:00:36pm
Do they have the pistons ???
24th Feb, 2010 at 04:06:03pm
On 24th Feb, 2010 Rod S said:
Do they have the pistons ??? No machine shop I've ever used would be prepared to bore a block without having the pistons (or at least one of them) in their hands to check it's actual measurement. Then all they would want to know is the clearance you want. yes they have all the pistons, med say that the running clearance of absolutely maximum 3 thu Yes i moved to the darkside |
24th Feb, 2010 at 04:09:41pm
I believe maximum standard clearance is 2.5thou.
Edited by John on 24th Feb, 2010. If something is worth doing, it's worth doing half of. |
24th Feb, 2010 at 04:11:12pm
Search and you will find!!!
24th Feb, 2010 at 04:13:40pm
im calling med back tomorrow and there going to measure a set of pistons for me , mr med thinks either my pistons are 2 thu too big or the machinists calliper is out, there going to bore my block and wait for final honing measurement Yes i moved to the darkside |
24th Feb, 2010 at 04:14:09pm
I've used 0.6mm (~2.5 thou) but that is on the high side for a non-turbo road car.
24th Feb, 2010 at 04:17:44pm
On 24th Feb, 2010 Brett said:
im calling med back tomorrow and there going to measure a set of pistons for me , mr med thinks either my pistons are 2 thu too big or the machinists calliper is out, there going to bore my block and wait for final honing measurement If the machinist is using a caliper to measure the piston diameter, I would take the block and pistons somewhere else...... And if he was using a proper micrometer, it would have a test piece in the box to make sure it was reading right before using it...... And if it didn't or they don't know how to use it, I would definately take it all elsewhere. Schrödinger's cat - so which one am I ??? |
24th Feb, 2010 at 04:18:50pm
Drakes in Bradford come highly recommended. If something is worth doing, it's worth doing half of. |
24th Feb, 2010 at 04:21:39pm
I had no ill effects running 5 thou piston to bore clearence on my last engine.
66 Posts Member #: 8258 Advanced Member |
24th Feb, 2010 at 04:24:19pm
Speak to your piston supplier or manufacturer, different pistons ie material it's made of & piston style ie design of piston require different clearances |
24th Feb, 2010 at 04:26:59pm
If the machinist is using a caliper to measure the piston diameter, I would take the block and pistons somewhere else...... And if he was using a proper micrometer, it would have a test piece in the box to make sure it was reading right before using it...... And if it didn't or they don't know how to use it, I would definately take it all elsewhere. to be honest i dont know what they are using to measure it, i just called it a caliper as that is what i would use to measure it with my next best would be a tape measure
25th Feb, 2010 at 05:42:00pm
i think i am all sorted now, they was using micrometers, 3 to be exact, read by 4 different guys who all came to the same conclusion, the dimensions supplied was wrong. fortunately med was ably to give the skirt clearance's (rather than bore diameter) for the cast omega's at +0.020 inch.
Edited by Brett on 25th Feb, 2010. Yes i moved to the darkside |
