| Home > General Chat > Megajolt revisited | |||||||
80 Posts Member #: 4178 Advanced Member Chesterfield |
3rd Mar, 2010 at 09:18:00am
Hello fellas, could anyone throw a little light on the problem i'm having? new engine installed, mj, eids etc all stayed on the car when the previous engine was outed. installed the trigger wheel onto the crank pulley, ensured that no1 piston at tdc lined up the trigger wheel and vr sensor as described on the autolabs website,IE sensor 90 degrees before tdc and nothing. The timing is all to cock and it seems to be firing out of sequence.
I am nobody, nobody's perfect. Therefore I am perfect |
Forum Mod ![]() 1927 Posts Member #: 1761 Stalker Bristol |
3rd Mar, 2010 at 09:25:22am
It sounds like you have the HT leads plugged in the wrong order on the coil pack. Each HT lead terminal on the coilpack has a number, 1 - 4. This refers to cylinder number, so terminal one go to plug one and so on.
Edited by Carl S on 3rd Mar, 2010. |
3rd Mar, 2010 at 09:53:16am
I have checked the leads and they are all ok 1 to 2 to 2 etc but still just popping and backfiring.
3rd Mar, 2010 at 10:00:33am
If everything else stayed on the car and it worked before then the low voltage connections between EDIS and coilpack should still be right and the HT leads should still be right which only leaves the trigger wheel.
3rd Mar, 2010 at 10:32:24am
If it is popping and backfiring that suggests that the ignition is massively retarded. I would double check the timing wheel. remember the engine goes clockwise looking at the pulley. http://www.twin-turbo.co.uk
66 Posts Member #: 8258 Advanced Member |
3rd Mar, 2010 at 12:52:52pm
You may have blown the coil-pack if you have tested for a spark with all the plugs out & only earthed one plug at a time to test it as you probably would with an old dizzy set-up. :$
3rd Mar, 2010 at 01:20:36pm
I had a similar problem and it may not be your answer, but try putting the trigger wheel on 180 dgrees round from where you have it and see what happens. When I test for sparks I have a piece of 4mm alloy with 4 holes in it into which I have screwed 4 old plugs(they cut their own thread if you have sized the hole right) Then just earth the plate -I use a jump lead- and see if all 4 are sparking. |
3rd Mar, 2010 at 01:29:48pm
On 3rd Mar, 2010 tadge44 said:
try putting the trigger wheel on 180 dgrees round from where you have it and see what happens. Absolutely nothing noteworthy as it's a wasted spark system? On 12th Nov, 2009 Paul S said:
Gary's description is best |
3rd Mar, 2010 at 01:43:55pm
On 3rd Mar, 2010 Rod S said:
If everything else stayed on the car and it worked before then the low voltage connections between EDIS and coilpack should still be right and the HT leads should still be right which only leaves the trigger wheel. From your description it isn't the sensor that must be 90 BTDC, the sensor can be anywhere, what must happen is the missing tooth must be in alignment with the sensor with the engine 90 BTDC on No. 1 (or 4). The only other thing might be the trigger wheel was way out before and there is a massive offset entered in MJ. If he's using the same pulley/bracket etc though this wouldn't make a difference would it? |
3rd Mar, 2010 at 01:59:27pm
If everything else stayed on the car and it worked before then the low voltage connections between EDIS and coilpack should still be right and the HT leads should still be right which only leaves the trigger wheel. From your description it isn't the sensor that must be 90 BTDC, the sensor can be anywhere, what must happen is the missing tooth must be in alignment with the sensor with the engine 90 BTDC on No. 1 (or 4). The only other thing might be the trigger wheel was way out before and there is a massive offset entered in MJ. If he's using the same pulley/bracket etc though this wouldn't make a difference would it? No, not if it was the same pulley/bracket, but the fact he talks about lining the sensor up as per the Autolabs site in the first post, implies it isn't the same, or it wouldn't need lining up again ???. Also, as Ben says, the fact it fires the way it does certainly implies the timing is way out. Schrödinger's cat - so which one am I ??? |
3rd Mar, 2010 at 02:02:46pm
try putting the trigger wheel on 180 dgrees round from where you have it and see what happens. Absolutely nothing noteworthy as it's a wasted spark system? 180 degrees out is noteworthy as it fires 2/3 instead of 1/4. The engine cycle is 720 degrees so the wasted sparks occur every 360 degrees, not 180 :) Schrödinger's cat - so which one am I ??? |
3rd Mar, 2010 at 02:04:39pm
Yes i moved to the darkside |
3rd Mar, 2010 at 02:16:45pm
180 degrees out is noteworthy as it fires 2/3 instead of 1/4. The engine cycle is 720 degrees so the wasted sparks occur every 360 degrees, not 180 :) I'm an idiot. I was thinking cam degrees. *Hangs head* On 12th Nov, 2009 Paul S said:
3rd Mar, 2010 at 02:57:48pm
Engine at TDC yes, Sensor at 90 BTDC yes, Missing tooth at TDC do we know?
3rd Mar, 2010 at 03:31:56pm
The reason I say make sure the leads are connected in the correct order is because a lot of people think that putting the leads in firing order (1-3-4-2) corrosponding to the terminals on the coilpack, because of the way it is arranged, instead of matching the terminal numbers to the cylinder numbers.
![]() 9326 Posts Member #: 59 First mini turbo to get in the 12's & site perv Herefordshire |
3rd Mar, 2010 at 04:35:19pm
HAve you checked your map, mine some times vanishes over a long winter |
![]() 608 Posts Member #: 1106 Post Whore Hungerford, Berks |
3rd Mar, 2010 at 05:49:10pm
Based on my recent experience with setting up the trigger wheel for megasquirt, could the pulley timing mark be in the wrong place for the engine?? I found that mine was 16 teeth out:
’77 Clubman build thread
6th Mar, 2010 at 02:34:56pm
Sorted chaps, i'm officially a tool, I set the engine to tdc aligned the sensor with the missing tooth but forgot to offset the trigger wheel, i'm gonna blame it on being distracted but between us is because i'm a dick ; 0 I am nobody, nobody's perfect. Therefore I am perfect |
6th Mar, 2010 at 04:00:44pm
Glad you got it sorted. As with all these things it is easy to get wrong, but you are so sure it is right it confuses you. http://www.twin-turbo.co.uk
) with five wires with a crocodile clip at each end, so I connect a clip to each of the four plug bodies & the fifth leg to the body to earth it.
