Home > Help Needed / General Tech Chat > Rev counter with Megajolt
retroracer1380
Member #: 1972
Worcester
Hi, been fitting megajolt to the mini today, but am getting a bit confused with where to connect the rev counter and after searching it has made me more confused!
I have a Smiths rev counter (RVC), can i connect it to the tacho output on the megajolt plug, or does it need the diode circuit, or do i have to drill the edis plug and take a feed from there?
Any help much apreciated so i dont muck up my neat wiring ive been trying to do!
Alex1340
Member #: 111
Loughborough
mine comes straight off the mega jolts to the oringal tacho. can't remmber the pipe location on the multi plug but is was pritty easy.
retroracer1380
Member #: 1972
Worcester
In the fitting instructions it says not all rev counters work from the tacho output on the megajolt plug, does anyone know if mine will, before i dont run any wires into the cab from the coil pack?
Alex1340
Member #: 111
Loughborough
Well mine did. Where have you put the mega jolts? personly i would run one from the MJ to the tacho and see. I put mine in the glove box so cabling was easy.
philc
Member #: 1346
bromsgrove
i think it is number 11 on the molex, just connect your tacho to it
Mine doesn't work from the MJ. I will be wiring it straight into the Edis.
retroracer1380
Member #: 1972
Worcester
I wired it straight to the tacho out put on the megajolt in the end and its up and running with the rev counter working,
Brocky
Member #: 224
Katy TEXAS
Hi there retro racer,
Could you tell me which way around you wired up your rev counter please ??:)
I'm just about to wire up my rev counter as well.
I have a smiths one in the 3 clock binical. It has a black white wire and a light green / orange going to it.
The black white was from the old coil -ve and the green orange is from the white wire from the fuse box / ignition switch, so I guess this is 12v +ve.
Did you put the megajolt tacho out to the +ve (spade) ??
Also did you just ground the -ve side (i.e. Blk/w)
Brocky
retroracer1380
Member #: 1972
Worcester
Just put the megajolt 'tacho out' where the black and white wire is goin at the minute, then the green/orange is switched live, so yeh 12v +ve. Then if there is a earth spade on the tacho put this to earth somewhere on the body or if not, earth the rev counter through one of the mounting bolts.
Brocky
Member #: 224
Katy TEXAS
Hey Retro,
I just got around to running a wire from the MJ tacho out to the round connector on my rev counter, and Hey presto it works....:)
Thanks for the info, It's great when things just work, especially when you have been given the right advise.
Yet another problem solved by the number on resource !
Many thanks
Brocky
Edited by Brocky on 12th Jun, 2010.
