| Home > Help Needed / General Tech Chat > Manifold to turbo nuts. | |||||||
20th Apr, 2010 at 02:18:31pm
Finally got round to swapping my manifold over today so I can refit the engine.
20th Apr, 2010 at 02:26:42pm
I've used the original Metro ones as they (and the studs) are high alloy steel to withstand the heat.
Edited by Rod S on 20th Apr, 2010. Schrödinger's cat - so which one am I ??? |
20th Apr, 2010 at 02:41:51pm
Brilliant thanks rod!
![]() 370 Posts Member #: 181 Senior Member Chard, Somerset |
20th Apr, 2010 at 03:02:23pm
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=182296
Edited by n.g.l. on 20th Apr, 2010. |
20th Apr, 2010 at 03:04:28pm
On 20th Apr, 2010 richminiturbo. said:
Are you using any split washers or anything like that? No. One of the setups I got off eBay had a pair of linked tabplates (as well as the locking wire) so I've re-used those (but no locking wire). I don't normally use locktabs of any sort as they are usually so soft but there isn't any loctite that works in this temperature range and these locking plates seemed quite hard so I'm giving them a try. Long term I will switch to the self locking nuts (as per the Cossie setup) but not until I've finished testing as they have a habit of chewing the stud up when you remove them. Another thing I found is that one of the nuts can only be accessed by an open-ended spanner, not even a ring spanner ( because of the proximity of the turbine housing) so it is hard to get that one tightened adequately. And finally, are you using the proper metal gasket. The proper one is high alloy steel with a deformable seal ridge. If you are using normal exhaust gasket material, or copper as some use, it may compress in service letting the nuts go loose. Schrödinger's cat - so which one am I ??? |
20th Apr, 2010 at 05:08:18pm
I used the linked lock tabs that Rod mentions until I had broken off all the ears. I now use spare std Metro nuts as locknuts.I have used SS ;ockwire but without proper lockwire pliers its too tough to wind up with ordinary pliers.
