| Home > Help Needed / General Tech Chat > Misses slightly at low revs? | |||||||
455 Posts Member #: 1502 Senior Member Aberdeenshire, scotland. |
22nd May, 2010 at 08:03:24pm
Looking for some advice,
22nd May, 2010 at 08:33:12pm
it could be all sorts of things, mine started like this, then kept wiping out headgaskets, the end result i think the ring-lands went
Yes i moved to the darkside |
22nd May, 2010 at 08:38:41pm
Hmmm,
Edited by hammoj28turbo on 22nd May, 2010.
22nd May, 2010 at 09:23:46pm
Also just noticed it does it when you have the car in neutral.
22nd May, 2010 at 09:48:10pm
rich misfire?
22nd May, 2010 at 10:09:12pm
my pug did this i changed the plugs and it was fine, does it smell rich from the exhaust? Drives
22nd May, 2010 at 11:29:53pm
Brett, not sure about the noise. I could get a video up.
23rd May, 2010 at 09:30:13am
if the mixture is fine go for the coil first and check the dizzy cap and leads
23rd May, 2010 at 12:23:54pm
I think mixture must be fine, just put it away to be set up and rolling roaded so hope so. Will chekc plugs though.
24th May, 2010 at 10:26:11am
Had a look at plugs. Greyish brown colour so they look fine to me.
24th May, 2010 at 11:45:16pm
Im sure most standard N/A engines would use BPR6's im using BPR7's at the minute... could try some 7's?
25th May, 2010 at 11:02:17am
Johnny, Thanks for the info. Il work my way through that lot. Gives me somewhere to start. THanks
45 Posts Member #: 8924 Member New Zealand |
25th May, 2010 at 02:37:43pm
wat coil are you using?? NEW ZEALAND MIGLIA SPEC ROAD LEGAL TURBO MINI BUILD THREAD >>>
25th May, 2010 at 04:45:04pm
Not sure what coil im using.
26th May, 2010 at 06:25:45pm
hmm using the wrong coil can give you problems but if i remember correctly thats only with injection minis... cause they work differently somehow. just make sure it has a good blueish spark.. if its orangey then its generally weak |
28th May, 2010 at 04:36:09pm
Put a new coil on. A DLB198 and the misfires gone now. Edited by hammoj28turbo on 28th May, 2010.
