Home > Introduce Yourself > hi im corey from new zealand with a M.E.D 200HP build!!!!!
NZMED1293
Member #: 8924
New Zealand
:)hi , THIS WILL BE A BUILD TO WATCH!!!!
hmmmm $50,000 New Zealand Dollors to play with..
79 leyland shell
as of today, the car is a shell on a roller getting final rust repairs and new front wings replaced. has a welded in roll cage.
ENGINE: M.E.D 1293CC GROUP A engine with highly re-modified head. 4 SPD CLUTCHLESS DOGBOX..TRANEX LSD..COMP SHAFTS
custom fuel injection setup.
megasquirt ecu
s.t.i fuel rail. custom plenum. 140cc injectors x2. 80mm thrttle body off a holden barina.
4 pot 7.5" brake kit. anodised calipers. vented cross-drilled discs.
superfins on rear, highly detailed subframes and underbody...
:):):):):):):):):)*smiley**smiley**smiley*:$:$*surprised**surprised**happy**happy**oh well**tongue**indifferent**frown**frown**frown*:)*smiley**smiley**smiley*
BUILD 50% DONE. WILL POST REGULAR PICS OF IT. IM SURE LOTS OF PEOPLE WILL BE AMAZED...
NEW ZEALAND MIGLIA SPEC ROAD LEGAL TURBO MINI BUILD THREAD >>>
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=363477
Prawn
Member #: 5232
basingstoke
Sounds interesting!
Welcome to the forum.
What turbo are you going to be using?
jbelanger
Member #: 831
Montreal, Canada
Two 140cc injectors will not get you even close to 200HP. And are planning on doing port injection?
Jean
http://www.jbperf.com/
200bhp on 2 140cc injectors? is that a typo or is running lean the name of the game
Edit beaten to it!
Edited by wolfie on 23rd May, 2010.
Welcome.
I'm afraid that you will get some sceptical comments as far as the fuel injection is concerned.
I'm using a total of 4400 cc/min on my port injection to get around 250hp.
Have a read of this:
http://jbperf.com/sequential/Fuel_Injectin...e_A_Series.html
Ben H
Member #: 184
Melton Mowbray, Pie Country
Welcome, we already have the most amazing minis in the world on this forum, IMO so you have your work cut out.
Isn't 50,000 aus dollars something like £6.50????
http://www.twin-turbo.co.uk
Welcome mate.
IMO Nic Riz has the most amazing TurboMini on here as its so unassuming and goes very fast indeed.
Thats the one to beat
Paul
*Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping*
Hello and Welcome. Looking forward to seeing your build
Hello and welcome, get some pics up then i need AMAZED lol.
evolotion
Member #: 83
Glasgow, Scotland
Looking forrward to the build and results :) mind and post plenty of pics :)
Denis O'Brien.
EssexSteve
Member #: 7029
Wickford Essex
What he said!
just to echo, i will be amazed if throttle body injection** with 280cc worth off injectors and a 5 port head** gets you 200bhp...in na**, thats mental turbo range
** guesses due to lack of info
WELCOME , best of luck with your build , i think it will be fascinating to watch it progress .
its good seeing people do things new to them, with such enthusiasm .im sure ,with a bit of fine tuning ,it will be a great success ,get it all working right and youll easily see 200 bhp .
regards
robert .
AWDmoke
Member #: 713
Western Australia
Yes, but he said 50,000 NZ dollars, which is about £1.37 *tongue*
On 24th Dec, 2008 Nic said:
NZMED1293
Member #: 8924
New Zealand
hi people. i havent had the injection running. its jigged up at the moment so i guess ill come across the injectors not working. cheers for the info though..
50,000nzd converted is 23,327 pounds btw :)
will get some pics up soon.. have packages arriving daily..
pinkyandnobrain
Member #: 2588
Pretoria South Africa
Sounds good.
Please keep us posted about your progress.
"Try to take over the world!"
Welcome!
I'll be keeping my eye on this build. :)
Pantsly
Member #: 8805
$50000 = to 6.50 pound, bit cheeky seeing the way the pound has dropped well over half its value and we are 1 to 1 with the US dollar. Dont worry fellas we'll still bail you out when you countries broke (next week)*tongue* No offence meant, just having a dig.
A WARM! Welcome to turbominis
