Home > Technical Chat > twin carburettor
chominsh
Member #: 8160
, mitcham, surrey, london, cr4
is it possible to fit twin carburettor on mini metro turbo engine??
may be someone done it before? :)
Nothing special!
yep take the turbo off
Have a search as this has been talked about a few times, iirc charge robbing is the problem here
Edited by wolfie on 24th May, 2010.
chominsh
Member #: 8160
take turbo off? no :)
i was thinking twin carburettor connected to turbo unit? something like that :)
Nothing special!
give it a go then and let us know how you get on
chominsh
Member #: 8160
Nothing special!
chominsh
Member #: 8160
i decided to ask before fitting and buying parts :)
may be some one done it already :)
which carbs is the best to use?
Nothing special!
http://www.turbominis.co.uk/forums/index.php?p=search
fab
Member #: 100
Parisien Turbo Expert
Paris\' suburb
The first trouble will to find/build an inlet manifold to go with the std metro turbo one as none clear it.
Or make an of the shelf exhaust manifod (perhaps use a mirage one butI don't know if the mirage one could clear a twin carb inlet,
then choice of carbs: best would be a twin bike cv carbs, or a twin hif38. using a pitot tube to make the boost sens.
exactly what I was planning to make for five years, good luck for setting these *wink*
But the std mety set up can make enough torque /power to blow clutch/gears/diff/ continuing eating crank trust and bearings so why would I need twincarbs?
When I sometime think of these today, I end each time at looking to a 7 port set up, easier, and certainly not that far (cost/time wise).
fabrice
NZMED1293
Member #: 8924
New Zealand
twin hif44 would be a start...
NEW ZEALAND MIGLIA SPEC ROAD LEGAL TURBO MINI BUILD THREAD >>>
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=363477
Why? Miniwilliams makes around 300BHP using a single HIF44. Can't see any advantages to using any other carb.
Edited by apbellamy on 25th May, 2010.
NZMED1293
Member #: 8924
New Zealand
i was going to try this but APBELLAMY has a point. single hif44 is more simple and yet the power acheived is plenty enough..
The start of endless swearing, headaches etc
Correct, its been discussed time and time over, if you want to do it and have the material/skills to do then go for it. It will be different from the norm if you get it working, however as the lads say 1 carb ia fully upto to it.
NZMED1293
Member #: 8924
New Zealand
for another carb alternative you could use weber or dollorto sidedraft suck or blow through. ive seen both done successfully..turbo and supercharged
suck though i could see working but blow though really? any links?
iirc Robert runs a blow through webber/dollorto on his TVR, it has been boxed I believe.
NZMED1293
Member #: 8924
New Zealand
go on youtube and search for blow through turbo weber videos. theres vw turbos, cortinas, mostly older cars...i think i might have a link to kitting a weber dcoe for boost.
i mean on the siamesed 5 port head, plenty of flat 4 and others out there running blow though dellorto's inc lotus *wink* its easier without siamesed ports
Edited by wolfie on 25th May, 2010.
fab
Member #: 100
Paris\' suburb
revise your mind:
Jukka, Janspeed .
never seen one Fab
fab
Member #: 100
Paris\' suburb
If you never seen jukka's blow thru dellorto set up or a Janspeed one,
I'm now a bit embarrased,
look for jukka or janspeed in the search function of this nice forum,
perhaps Veg will disinterred one before....
fabrice
never seen one Fab
Edited by Turbo Phil on 25th May, 2010.
evolotion
Member #: 83
Glasgow, Scotland
y'know i cant even remember what jukka's setup looks like, but do remember admiring the work put in!
Denis O'Brien.
chominsh
Member #: 8160
thank you for advice :)
just want something different, hopes it will work :)
need to do more research :)
Nothing special!
jbelanger
Member #: 831
Montreal, Canada
I don't see why people won't consider EFI instead. I don't think it would be as complex as getting a correctly working twin carb setup (or Weber/Dellorto carb setup).
Jean
http://www.jbperf.com/
