Home > Wanted > complete mega jolt/squirt set up for turbo mini ...???
NZMED1293
Member #: 8924
New Zealand
hi im from new zealand.
after a complete megasquirt standalone fuel and spark setup. brother in law installs high performance ecu's so ill have no porblem with that.
NEW ZEALAND MIGLIA SPEC ROAD LEGAL TURBO MINI BUILD THREAD >>>
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=363477
jbelanger
Member #: 831
Montreal, Canada
You'll want to read up on what is actually needed in the appropriate section of this forum. There is a lot of information on what is needed but there is also a lot to absorb before you start.
And your best bet will be to talk to the DIYAutotune.com guys. They're in the US but they'll most likely give you the best price and the best service. If you can find someone local then go for it but you'll likely have to pay for the convenience (which might not be an issue for you...)
Jean
http://www.jbperf.com/
Ben H
Member #: 184
Melton Mowbray, Pie Country
If you have the money ditch the 5 port and talk to Specialist Components about their 7 or 8 port heads. Good value for money and more or less bolt on, perfect.
http://www.twin-turbo.co.uk
