Home > Help Needed / General Tech Chat > Rust! - 1) Is this fixable - and - 2) Can anyone here do it?
Hello chaps
My car has been away at GSMotorsport for a while now, and Phil has made some excellent progress, but we've reached a point where he can go no further. For both time and knowldge-of-mini reasons, he doesn't feel confident to attempt this.
The whole corner of the shell seems to be rotten. It failed the MTO on it a few moths ago, and they didnt spot how bad it was. After a good poke and what not, Phil discovered that it was full of filler, and, horribly rotten. It's the bit behind the front wheel arch, including the bottom of the A-panel, and around that area. The pics will help to see.
So, firstly, is the shell fixable?
and second, is there anyone here would thinks they would be up for the task? I am happy to pay, but would rather I was paying a decent person on here, than some shite bodyshop.
(I'm not fussed about the way it looks, just want it MOTable. I'll be getting the car re-painted in the next 12-24 months anyway.)
Pics:
Cheers. :/
-a
Definitely fix able, I have come across a hell of a lot worse.
I would have thought that there are loads of TM members that could sort it, unfortunately I barely have time to eat sleep & shit at the moment so working on cars is a no go.
nutter driver
Member #: 47
Not very sunny swanage
very fixable, cant help with fixing it though im afraid.
At least that's something - cheers guys. I know nothing about rust/welding.
It is fixable, and my only advice is to make sure you use genuine panels for the A post and A post stiffner, all others seem to be a different shape completely. Infact you can buy a complete inner wing/ flitch pannel, with A post stiffner, and A panel as one, you then only need the A post closing panel and doorstep/ A post panel. How bad is the scuttle?
Yes defo fixable, and yes use a gen a panel, ive found mini machine bits are good quality aswell, they could even weld most of it together for you.
rick
ps sorry as others, am struggling to do anything on mine at the mo.
we do however use a gent to help us at work time to time when were busy and he loves fabricating bits, the down side is distance i supose.
Jackman
Member #: 984
Westhoughton, Bolton
The answer is yes, i have done that and some more on my estate.
Yes it was used as a shed for awhile.
Currently it has no floor in it.
Manchester Minis
wow at jackman *happy* and alex definately fixable i did similar to my clubby this year not quite to that extent but might aswell have been some pics are in my built thread in my sig *happy*
I've done the outer A post on my mini, it's not difficult. Then it's just a case of the inner bit and an A panel. Probably a days work, again time and distance are the only things stopping me helping.
Here's the main panel you need,personally I would just cut a section out and but weld it in.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...em=250638410173
Then it's just a genuine sill step (they have the A post) and an A panel.
very fixable and i have a hinge panel here you can have
That's similar to a problem we found with sturgeo's Flame:
You'll need to cut off the A panel, weld in a couple of new plates and fit a new A panel.
Really should only take a few hours. Just need a Mig welder, angle grinder, clamps and hammers.
Anyone near Alex have a Mig with a 13A plug?
yes i do
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Yep...very fixable. New 'A' panel the rest you could make yourself with abit of tin. *wink*
Edit; You can problably save the panel to be honest. Cut out the rest of the filler/rot...I may be able to help. Not a promise mind! *happy*
Edited by Jason G on 6th Jun, 2010.
On 19th Jan, 2010 wil_h said:
Cool. Thanks for the advice and what-not guys. If any of you do feel like helping, I'll pay for time and parts, as said above.
I dont have the car back yet, mind. It's currently near Avon, I tink..
If you are not sorted by August I'll do it for you buddy.
Cheers Tom - I'll keep you posted
Mr Joshua
Member #: 1954
Luton Bedfordshire
I agree that this is repairable and not a big job if you know what you are doing but having done a job like this I will say be prepared to cut out a lot more of the car than you considered, a lot more!
Own the day
CH007
Member #: 8863
As others have already said it is likely that more has gone. It looks same as mine was and required scuttle repair and under scuttle along with half inner arch and hinge panel etc. I used Hadrian panels but they are slightly different shape etc.
I work in Alton at present during day so could pop by and offer some guidance etc although my welder is too big to sling in back of car.
If it was complete new panels I have spot welder here that could throw in car but for repairs you need to seam weld it.
Once again I clutter up a thread but offer nothing of value*happy*
too late
http://www.turbominis.co.uk/forums/index.p...d=175776&fr=200
