| Home > Help Needed / General Tech Chat > sill removal | |||||||
67 Posts Member #: 8744 Advanced Member |
27th Jun, 2010 at 06:22:14pm
hi im at the stage where i have to do body repairs and need to remove both sills, but am struggleing getting them off any hints will be apreceated thanks mike |
27th Jun, 2010 at 06:30:32pm
Angle grinder! Stick it in just below the top lip, but skip the ends and middle bit where the jacking point is/should be. Get them with a chisel or shears. Then just fold it down and hack the rest off, then tidy it up with grinding disks and flap wheels. Piece of cake.
549 Posts Member #: 5327 Post Whore Dudley, West mids |
27th Jun, 2010 at 07:28:24pm
Yep just as apbellamy says. I use a 1mm cutting disc on my grinder and cut just under the sill lip. Then bend this back and use a sharp chisel top break the spot weld that hold it to the floorpan. Simple. |
27th Jun, 2010 at 07:36:18pm
got one side sort of off but were the sill meets door step how do you seperate them bits? |
27th Jun, 2010 at 07:39:18pm
and do i have to brace the car in any way if im also changeing the inner sill and floorpan? |
27th Jun, 2010 at 07:51:02pm
Thin the bits that are left behind with the grinder then peal them of with a pair of pliers, like you're opening a tin of spam.
27th Jun, 2010 at 08:01:49pm
ohh i never thought of peeling it like that i was trying to chisle it off but was bending the top lip! and yeah all the floors, now i have the sill off i recon its best just to get one of them full floors that have ths sill atached on it already! any one know of the best place to get them from? thanks mike |
27th Jun, 2010 at 08:17:59pm
i find these work a treat for general grinding, On 28th Aug, 2011 Kean said:
27th Jun, 2010 at 08:24:13pm
whats that mini13? |
27th Jun, 2010 at 08:40:03pm
doh!
27th Jun, 2010 at 09:11:39pm
I use ordinary grinding disks to get the majority of (as they are cheap), then clean it up with a flap wheel.
27th Jun, 2010 at 10:43:10pm
dose anyone know were i can get a whole floor pan with the outer sill atached? |
28th Jun, 2010 at 08:30:05am
I've only ever seen half floors (full length but left side or right side halves) with sills pre-attached.
28th Jun, 2010 at 09:14:44am
Just glue another one over the top and underseal lol! (waiting for Norwegian rant!) On 5th Sep, 2011 Vegard said:
28th Jun, 2010 at 10:10:50am
Is that how your racecar is done Scruffy ? :)
Edited by miniminor63 on 28th Jun, 2010. |
28th Jun, 2010 at 10:53:45am
The inner sill has gone rusty most of the way along and just want to get it done propley first time and the front footwells arnt rusty they are just dented were someone jacked it up! Ohh and I was on about the full lenght half floors! Thanks mike |
28th Jun, 2010 at 11:22:37am
On 28th Jun, 2010 turbomikee said:
Ohh and I was on about the full lenght half floors! ....in which case MiniSpares sell half floors with sills attached. But seperate half floors and seperate sills are a lot cheaper especially if you use another supplier who only sells them seperately (I just bought some from DSN for my second project). Schrödinger's cat - so which one am I ??? |
28th Jun, 2010 at 11:25:26am
On 28th Jun, 2010 miniminor63 said: Is that how your racecar is done Scruffy ? :) <---
28th Jun, 2010 at 12:53:16pm
Have you got dsn's website mate? |
28th Jun, 2010 at 01:16:39pm
Have you got dsn's website mate? http://www.dsnclassics.co.uk/acatalog/DSN_..._Panels_52.html You'll find floor halves about 1/4 way down (I can't link to individual items on their website). I use them because they are local to me (so I could collect them), not sure what carriage charges would be for such large items but I guess that's true for anyone unless you have a specialist local to you where you can collect. Edited by Rod S on 28th Jun, 2010. Schrödinger's cat - so which one am I ??? |
28th Jun, 2010 at 02:28:14pm
Hmm they seem quite reasonable! What is the panel fitment like Rod? https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
28th Jun, 2010 at 02:46:51pm
On 28th Jun, 2010 matty said:
Hmm they seem quite reasonable! What is the panel fitment like Rod? I haven't fitted them yet Matty, they are in the back of my LandRover waiting for the second project..... They are made by Magnum who do a lot of the non-genuine Mini stuff. A lot of the panels I had from DSN for the first project were Magnum and all their stuff I've used so far has been quite reasonable for fit. These must be from fairly new dies as well as all the corners and the ribs along the floor etc have nice clean, square edges. When I first looked at them Dave Senior (the DS part of DSN) said he had used them on his daughter's car and had found them a good fit and I "think" that's the shell that's now with John K. If you want any close-up photos of any particular areas, just let me know. Schrödinger's cat - so which one am I ??? |
