Home > Help Needed / General Tech Chat > Good, shit, overkill?
analogue_radio
Member #: 4600
Melton Mowbray,
near Leicester
Caught my eye as its shiny and new!
http://cgi.ebay.co.uk/Alloy-Front-Mount-Un...#ht_5490wt_1139
It will also fit in the grille, but is it just some tosh? It is a UK based company, although it could come from China.
kenny2
Member #: 5362
wexford in ireland
looks neat!! mite purcase one for both my cars, mini and starlet
On 5th Jan, 2011 wolfie said:
looks nice and for that price i would want to know the efficincey of the intercooler and the pressure drop across it ?
analogue_radio
Member #: 4600
Melton Mowbray,
near Leicester
Is it worth me taking a chance, I mean I'm only running a timid 998 turbo.. so I'm not exactly pushing anything. Think it's worth a punt?
All of the egay stuff use shite cores from fuck knows where. They usually get away with performing ok because the cores are much bigger than actually needed.
So no doubt it would work fine.
If you look inside the tubes, pressure drop will likely be minimal, because there is very little to restrict the airflow. Of course, the other side of that means that little actual cooling will take place because the air just shoots straight through.
But for a 998 turbo, I'd imagine it would be more than adequate.
Edited by stevieturbo on 17th Jul, 2010.
Star Mag
Member #: 375
Leicestershire
Wasnt there a thread about this recently??
Rod S had a thread about these cheaper intercoolers, probably best to look at that as he did some fairly scientific testing
analogue_radio
Member #: 4600
Melton Mowbray,
near Leicester
Cheers for the name, I searched for intercoolers and it came up with hundreds of results.
Ours looks very similar to that on the TT, has reasonable looking internals and seems to do the job.
Compared to some of the OEM stuff I've used it looks pretty similar, but I've never tested efficiency, pressure drop or flow. But it's hot at one end and cold at the other, which is all you want.
I'd be interested in to read the thread mentioned above though.
there you go will
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=371421
mayoturbo
Member #: 1395
chepstow
Time to look for a new intercooler for me then...
