| Home > Help Needed / General Tech Chat > na 1380 build | |||||||
17th Jul, 2010 at 07:36:59pm
hi
My build thread..
17th Jul, 2010 at 07:55:52pm
depends on what you want from the car. If you like low end grunt and an engine that stops delivering at 6-6.5k it is a good choice. if you want something a bit more race with more peaky higher power I would get something a bit more "wild" |
18th Jul, 2010 at 12:00:41pm
like a 286 cam? My build thread..
18th Jul, 2010 at 04:31:31pm
you will find the sw5 is a cracking cam, i would leave that in and see how you like it ......?
18th Jul, 2010 at 08:48:35pm
ok i just thought that the sw5 is a bit wasted with the high cr and the fact it revs up to 7000rpm!
My build thread..
![]() 1137 Posts Member #: 1450 Post Whore Near Paris - France |
19th Jul, 2010 at 08:53:51pm
Because it can run up to 7K doesn't mean it needs to.
Rusty by nature
They said "That sounds rough mate." I said "Cheers it cost me a fortune to make it sound like that!" |
19th Jul, 2010 at 10:06:46pm
Sorry to be a bit of a na sayer but IMO the SW5 has no place in a big bore motor it is perfect for hot small bore motors, but it lacks Lift and duration for a big motor IMHO. the Kent 266 is the best big bore cam for street use it gives a fantastic power curve and a mind blowing amount of torque My last 1480 had this cam with a set of twin 1.5 SU and a good head and made well over 90 ft/lb torque at 3000rpm an animal of an engine I loved it and wish I never changed it for the 286 although a great cam for fast road track it just never had the feal of the 266. On 17th Feb, 2009 Rob H said:
20th Jul, 2010 at 07:14:07pm
i have driven it with the sw5 in it, but just thought with the high cr it could benifit from somthing a bit more livley.
My build thread..
20th Jul, 2010 at 07:33:57pm
Look what I found with the hidden search button :
Rusty by nature
20th Jul, 2010 at 07:52:48pm
cheers mate
My build thread..
20th Jul, 2010 at 09:17:12pm
SW10 helped me Rusty by nature
