Home > Help Needed / General Tech Chat > those small clutch and brake cylinders
blister
Member #: 2590
Croydon
been seeing a lot of minis recently with very small brake and clutch cylinders
where are they from and has anyone got any photos? or any more information?
blister
Member #: 2590
Croydon
just done a search and i think i should put my set up at the moment
front 4 pot alloy mini spares
drear finned drums
front and back braded lines
dual system master cylinder
1984 mini city
girling?
Mine are AP Racing. Can just see them here
If you painted that engine red you would run a 12
blister
Member #: 2590
Croydon
those are the cylinders i was talking about but my left cylinder has two pipes coming off. can you get those small cylinders with the two pipes
You just need a T piece to split between front and rear, and then a limiting valve on the rear pipe.
However they dont make any improvement to the brakes, just looks and they end up taking a fair bit of fiddling to get right
Here you go:
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=302530
Edited by Nic on 21st Aug, 2010.
Id look gay too
blister
Member #: 2590
Croydon
reason i ask is because the supercharger set up i am running means the weber has to sit where the brake master cylinder would be and i can only have two of those small bake bean can ones but as i have one tandem brake master cylinder its in the way
