| Home > Help Needed / General Tech Chat > Left to Right positioning on KAD internal gear linkage | |||||||
478 Posts Member #: 1962 Senior Member Lancaster |
8th Sep, 2010 at 10:15:16pm
Gents
Edited by tomkidd on 8th Sep, 2010. |
8th Sep, 2010 at 10:26:54pm
Left a bit....
8th Sep, 2010 at 10:36:44pm
As jos says, left a bit. in theory you can go a bit highter,lower or either side as the uj's will line it up.
9th Sep, 2010 at 10:00:27am
On 8th Sep, 2010 cossierick said:
As jos says, left a bit. in theory you can go a bit highter,lower or either side as the uj's will line it up. Rick ps, that shell looks mint, have i missed your build pics somwhere ? Cheers guys, much appreciated. I've not really documented the build on here as its non turbo
But can copy it all in if anyone is interested? |
9th Sep, 2010 at 10:07:45am
I'd be interested to see your car. The bits I can see look to be done to a high standard On 11th Feb, 2015 robert said:
9th Sep, 2010 at 10:35:48am
Cheers, here's a link if anyone is interested http://www.turbominis.co.uk/forums/index.php?p=vt&tid=381837 |
9th Sep, 2010 at 10:37:56am
Fit the handbrake first to make sure it clears and you can get your hand down the side i leave the handbrake on 1 click so there is more room, Prawn very kindly gave me all the measurements from his car, i can find you the pic if you like. Edited by t3gav on 9th Sep, 2010. |
9th Sep, 2010 at 06:32:28pm
There is lots of pics of the kit on my build on here have a look mate hole this helps it was a pig of a job and wish i had done it before piant .
