Home > Help Needed / General Tech Chat > electric waterpump
clubbie70
Member #: 8935
netherlands
hi all, does anyone now thes waterpumps, and would they be up to do the job??
thanx
http://www.johnson-pump.com/JPMarine/produ...ation/cmco.html
G13B
Member #: 1376
I´m installing one in my car linked to a alloy rad, yet to see if it works though*wink*
it should be far superior (more flow) too the bosch charge cooler ones
//marcus
clubbie70
Member #: 8935
netherlands
ok. let me now if it works:) I assume you use it as your main pump and not as an extra.
Do you fit an electric controller to it?
rob
Hi mate, this is what i am running with no over heating problems, even with its biggest road test which was 12 runs at pod then straight down the M40 for 2hrs. I think my pump is the same as the one on the link not too sure if it has 19mm or 20mm outlets i can`t think at the min.
Have a look at the pics on here.
http://www.turbominis.co.uk/forums/index.p...id=334111&fr=25
http://www.turbominis.co.uk/forums/index.p...d=294168&fr=125
Hope this helps Simon.
clubbie70
Member #: 8935
netherlands
GREAT CAR .... i like :):)
Thing that worries me about the johnson pump is
Liquid temperature: -30°C – +100°C (-22°F – 212°F)
i havent looked into it my self yet but i think the placement of the pump is after radiator, the water after radiator shouldnt be over 100°C imo
the coolant temp is usually measured after the engine ( water at its hottest point)
Thank you.
G13B
Member #: 1376
rob
yep main pump, no controller, front mounted std size alloy rad
i have the cm30 one*wink*
god to hear that your pump is working madmk1,
i guess it pretty similar design/capacity as the johnsson
wonder if you gain a couple of horsies on top with the mech waterpump disconnected…
