| Home > Help Needed / General Tech Chat > Shell/Body modifications | |||||||
![]() 847 Posts Member #: 6673 Post Whore Worral Sheffield |
25th Sep, 2010 at 11:11:54am
I was wondering while my shell is stripped is there any little mod's i should do while i have the chance?
1391 Posts Member #: 1686 Post Whore Oxford |
25th Sep, 2010 at 12:39:40pm
Inner head lining rail if you don`t want a head lining. Tub the rear arches. Flat boot floor perhaps? On 19th Feb, 2011 Miniwilliams said:
OMG Robert that's a big one |
25th Sep, 2010 at 03:46:17pm
I'm getting rid of the battery box in favour of a bracket for a gel battery.
25th Sep, 2010 at 07:51:17pm
Andy Fiberglass!? you feeling ok?
25th Sep, 2010 at 07:57:12pm
Plastic bonnet and boot too....
1083 Posts Member #: 8932 Post Whore |
26th Sep, 2010 at 12:07:37am
To anyone who has removed the headlining rail, where have you cut it out? and was it just a case of getting stuck in with the angle grinder? would it be possible to send me a picture as thats something i want to do to mine. Thanks in advance.
Edited by george91 on 26th Sep, 2010. |
26th Sep, 2010 at 09:44:44am
Have a look about 1/3 of the way down here
27th Sep, 2010 at 12:39:33pm
Bottom of the the door hinge panel where it meets the bottom of the A panel and front of the door step. This is where water gets in and rots out the front of your sills. The panels but up here but are not sealed. Own the day
27th Sep, 2010 at 01:01:02pm
Cheers Josh, I have replaced both sills and the panel in question and have made sure they are nicely sealed |
28th Sep, 2010 at 11:57:30am
On 26th Sep, 2010 apbellamy said:
Have a look about 1/3 of the way down here http://www.turbominis.co.uk/forums/index.p...id=259072&fr=75 Thankyou :) |
28th Sep, 2010 at 12:02:33pm
Why wouldn't you like to keep the battery where it originally is? On 13th Jul, 2012 Ben H said:
28th Sep, 2010 at 12:07:51pm
I'm using a Gel battery, so have ellected to move it further up onto the boot floor and loose the battery box. Primarily for weight reduction, but also to remove the box from the flow of air under the car. I will be 'boxing in' the under side of the subframe with ALU sheet so wanted to make it as flat as possible. On 11th Feb, 2015 robert said:
28th Sep, 2010 at 03:29:25pm
Ive moved my battery to above the wok. You may aswell get the weight over the front wheels if you're going to move it. You save plenty of weight in cable too. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
28th Sep, 2010 at 03:35:34pm
That's not a bad plan Matty. Any pic's?
