| Home > General Chat > ignitoin wiring | |||||||
2 Posts Member #: 9082 Junior Member southampton |
26th Sep, 2010 at 04:35:37pm
hi.. i have a mini with mg metro turbo engine in it and i having a problem with the ignition wirng. my problem is on the distributor there is a small control box on one side with 2 male spade connectors, which go to the coil. im not sure which one is positve and which one is negative. (top or bottom). thanks |
26th Sep, 2010 at 04:47:11pm
Search, Search, Search, Search....
http://www.twin-turbo.co.uk
26th Sep, 2010 at 04:55:18pm
thats great , thanks |
26th Sep, 2010 at 05:44:07pm
On 26th Sep, 2010 Ben H said:
Search, Search, Search, Search.... And if you have the correct plug (which will only fit one way to the electronic module), with the correct wires, up to the correct connectors to the correct coil, they will only fit one way (as they are male and female connectors) and you wouldn't need to search. Seriously, use the right parts and you don't have a problem, they only go together one way around. If you have a mixture of all the wrong parts, the best bet is module "top" (the one parallel to the module) is coil +ve and battery, (usually a white wire) and module "bottom" (90 degrees to the module) is coil -ve and rev counter (usually a black/white wire). If you have a three pin module it's all different again but, again, the right parts only fit one way. Use my advice at your peril if you don't have the right parts, one wrong connection and the module is toast. :) EDIT - just realised Ben's link is where I posted the same two years ago I assumed at first, it was just a link to the search button.... I'm getting very cynical in old age
Edited by Rod S on 26th Sep, 2010. Schrödinger's cat - so which one am I ??? |
26th Sep, 2010 at 09:24:49pm
On 26th Sep, 2010 Rod S said:
EDIT - just realised Ben's link is where I posted the same two years ago I assumed at first, it was just a link to the search button.... I'm getting very cynical in old age ![]() That's not a bad idea, but I like to give people a chance. http://www.twin-turbo.co.uk
