Home > Help Needed / General Tech Chat > Turbo Carb possibilities?
yellowmini
Member #: 9040
Worcester
Is it possible to use the webber carb from a Renault 5 turbo, as i do have one, but am unsure as to how good it would be if its even usable.
Or alternatively which carb would be best to use if given the choice of any?
Ta
Advantage
Member #: 1450
Near Paris - France
What year ?
The R5 Alpine Turbo is suck through so not turbo savvy.
The R5 GT Turbo on the other end is a blow trought setup but it is a 32 mm bore (and a Solex item IIRC).
To me it is simpler and cheaper to convert a HiF 44 to turbo spec as shown in some thread here.
Rusty by nature
Adam_R
Member #: 1938
near Dundee
or even simpley still buy a turbo carb?
like this one
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...e=STRK:MEWAX:IT
*wink*
Gaball
Member #: 7169
Gobshite that posts wank videos.
Somerset, UK
What are the possible issues if any using a R5 GT carb was planning on using one because I have one
Gaball said:
Motorsport Engineering Student
Project Car 1293 Turbo Mini (on a student budget)
On 7th Oct, 2010 apbellamy said:
Carbon but plug?
Advantage
Member #: 1450
Near Paris - France
Possible issues are :
- sourcing a manifold as the carb is downdraft
- tuning of the carb as it is meant to go on a 1400 => you'll have to buy jets, chokes, and so on (with the SU, you have to buy needles but they are cheaper and you can tune them)
Also, you already have a SU too and the conversion is quite cheap.
But then it's your call
Rusty by nature
Gaball
Member #: 7169
Somerset, UK
Bugger dint think of that :/
A Hif44 conversion is simple then? What's it involve? work out cheaper then buying a turbo carb aswell I'm guessing
Carbon but plug?
wintersurferuk
Member #: 2208
you could prob get a carb inlet and plenum for under £100, bolt it on maybe get the needle profiled, job done!
Advantage
Member #: 1450
Near Paris - France
Everything you need to know is here.
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=241013
Have fun*happy*
Rusty by nature
