| Home > Help Needed / General Tech Chat > Part Throttle Det Pre boost - Has anyone had this | |||||||
809 Posts Member #: 224 Post Whore Katy TEXAS |
8th Oct, 2010 at 02:52:26pm
Gents,
8th Oct, 2010 at 03:00:56pm
Do you have a wideband fitted, what is the fuelling doing at this point?
8th Oct, 2010 at 03:09:07pm
Wrong damper oil in the carb, causing it to go mega lean? On 11th Feb, 2015 robert said:
8th Oct, 2010 at 03:18:25pm
8th Oct, 2010 at 03:20:05pm
It sounds similar to the Van. Leaning out on transition. If something is worth doing, it's worth doing half of. |
8th Oct, 2010 at 03:21:45pm
I will re check the oil level just to be sure, I did wonder if the spring might be too weak also.
On 8th Oct, 2010 apbellamy said:
Wrong damper oil in the carb, causing it to go mega lean? BTW - I took my buddy VTEC Pete out for a spin this weekend, and even though I am running her in, he gave it a name, the "Brocket"...cause I'm a brocket maaannn, nah nah nah nah nah nah nah nah nah nah nah....
8th Oct, 2010 at 03:23:14pm
How did you fix it ?
On 8th Oct, 2010 John said:
It sounds similar to the Van. Leaning out on transition. BTW - I took my buddy VTEC Pete out for a spin this weekend, and even though I am running her in, he gave it a name, the "Brocket"...cause I'm a brocket maaannn, nah nah nah nah nah nah nah nah nah nah nah....
8th Oct, 2010 at 03:31:44pm
too much ignition advance in that region of the map to begin with? Yes i moved to the darkside |
8th Oct, 2010 at 03:33:14pm
Do you have the part throttle lean off pipe blocked? If not I recommend doing it.
8th Oct, 2010 at 03:45:23pm
Thats what I was thinking, but fueling might be the root cause...
On 8th Oct, 2010 Brett said:
too much ignition advance in that region of the map to begin with? Edited by Brocky on 8th Oct, 2010. BTW - I took my buddy VTEC Pete out for a spin this weekend, and even though I am running her in, he gave it a name, the "Brocket"...cause I'm a brocket maaannn, nah nah nah nah nah nah nah nah nah nah nah....
8th Oct, 2010 at 03:45:57pm
Lean off is blocked :)
On 8th Oct, 2010 t2clubby said:
Do you have the part throttle lean off pipe blocked? If not I recommend doing it. BTW - I took my buddy VTEC Pete out for a spin this weekend, and even though I am running her in, he gave it a name, the "Brocket"...cause I'm a brocket maaannn, nah nah nah nah nah nah nah nah nah nah nah....
9th Oct, 2010 at 07:00:14am
by 10 pi needle and spring do you mean avonbar one? |
9th Oct, 2010 at 07:04:45pm
itll be a "lean tip in" get it on throttle transients all the time, solution is to increase acceleration enrichment, on an SU, i would be playing with the spring (heavier) or heavier dashpot oil, OR thinning down the needle so the part jsut forther down of your cruise location is slightly richer, youll need some way to gauge where the needle sits at cruise to do this accurately though :) turbo 16v k-series 11.9@118.9 :)
10th Oct, 2010 at 10:30:00am
So how much timing do you actually have at these points ? 9.85 @ 145mph
10th Oct, 2010 at 04:35:44pm
Hey Stevie,
10th Oct, 2010 at 04:36:23pm
Yes
On 9th Oct, 2010 fab said:
by 10 pi needle and spring do you mean avonbar one? BTW - I took my buddy VTEC Pete out for a spin this weekend, and even though I am running her in, he gave it a name, the "Brocket"...cause I'm a brocket maaannn, nah nah nah nah nah nah nah nah nah nah nah....
10th Oct, 2010 at 05:22:11pm
On 10th Oct, 2010 Brocky said:
Hey Stevie, I have been playing with the map and I have retarded the timming at the transition point to: 27 at 2 - 2.5 rpm 28 at 2.5 - 3.0 rpm 29 at 3.0 - 3.5 rpm etc The pinking has stopped. Are these figures typical or am I over compensating on backing of the timming to fix another issue say lean out ? The trigger wheel and bracket should be spot on in terms of offset as they were from Tom F. impossible to say if your lean without a wideband :) turbo 16v k-series 11.9@118.9 :)
10th Oct, 2010 at 05:29:18pm
Hey evo
Hey Stevie, I have been playing with the map and I have retarded the timming at the transition point to: 27 at 2 - 2.5 rpm 28 at 2.5 - 3.0 rpm 29 at 3.0 - 3.5 rpm etc The pinking has stopped. Are these figures typical or am I over compensating on backing of the timming to fix another issue say lean out ? The trigger wheel and bracket should be spot on in terms of offset as they were from Tom F. impossible to say if your lean without a wideband :) Edited by Brocky on 10th Oct, 2010. BTW - I took my buddy VTEC Pete out for a spin this weekend, and even though I am running her in, he gave it a name, the "Brocket"...cause I'm a brocket maaannn, nah nah nah nah nah nah nah nah nah nah nah....
10th Oct, 2010 at 05:56:12pm
The avonbar 10 psi should be on the rich side |
10th Oct, 2010 at 06:42:17pm
So how much timing did you have in there ??
2646 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
10th Oct, 2010 at 07:17:49pm
Do you have the part throttle lean off pipe blocked? If not I recommend doing it. |
