Home > Help Needed / General Tech Chat > faster spool on a t3?
eden7842
Member #: 8852
leicestershire
hey
is there any way to make my t3 spool faster? ive got a big intercooler and its spools around 3800rpm
cheers eden
change it to a better turbo ? lol
Timing, fuel, boost control setup, wastegate actuator etc can all make a difference
eden7842
Member #: 8852
leicestershire
i was thinkin the actuator wat are my optiontions with that?
Star Mag
Member #: 375
Leicestershire
Which T3 is it? Sounds ok for a standard metro unit.
They do feel laggy even more so when on low boost as there isnt a very big kick!
fab
Member #: 100
Parisien Turbo Expert
Paris\' suburb
install a bov it'll help your big turbo to spool to free atm before seing boost
eden7842
Member #: 8852
leicestershire
its a standard metro t3
fab: wats a bov?
On 10th Oct, 2010 eden7842 said:
fab: wats a bov?
ptchsshhhhhhh *happy*
Johnny
Member #: 6926
Accrington
blow off valve, dv dump valve *wink* the reason we have a turbo *wink*
nope,
Bite marks in the seat is why I have a turbo!
eden7842
Member #: 8852
leicestershire
i hate dump valves. ive just left it to chatter atm
fab
Member #: 100
Paris\' suburb
you can make it recirculating to the compressor inlet if you don't want tit to be noisey
Johnny
Member #: 6926
Accrington
isnt the chatter bad for the bearings in the turbo?
eden7842
Member #: 8852
leicestershire
never thought of that. ive been out i it today and it spools around 3500 which isent to bad really. just carnt stop the damm thing getting hot!
That would be the last possible reason I'd ever have a turbo. First would be to make power.
And a BOV will make no difference whatsoever to spool rpm.
Depending on actuator, a weak one or one not pulled up tight enough could crack open earlier making it lazier to build boost.
As could wrong fuelling, wrong timing etc etc
Johnny
Member #: 6926
Accrington
true, true, sometimes i like the lagg on my t3 as it comes in all at once and feeeels great! as for spooling quicker like people have said those are the main options except getting a smaller turbo
fab
Member #: 100
Paris\' suburb
Your dumpvalve, if your taking his vaccum from the inlet manifold, will see vaccum when your not on boost, thus let your compressor speeding to free atmosphere before shutting the valve, I've used this mod a la priority breather valve on my big k16 with good effect.
Advantage
Member #: 1450
Near Paris - France
Alpa was looking for the same issue and got some answers.
I'll try and find the thread.
Edit, here is the link
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=371259
Not very useful I'm affraid
Edited by Advantage on 10th Oct, 2010.
Rusty by nature
chinlesswonder
Member #: 1192
In the garage......again!!
A decent shot of nos should give it a kick start.
133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
Shakespear RWYB 14.995 91.83mph
I wouldn't mind a 25hp kit for the van :)
Either that or a better turbo!
jamz
Member #: 2292
Tool
Herne Bay, kent
i i stick with a t3 i was thinking about a 25bhp kit for preboost
cant beat a good blowout.
Increase the CR?
Might have little affect on spool times, but will help the car feel less laggy.
tadge44
Member #: 2500
Buckinghamshire
Laughing gas is the only proper answer !!
Go for it - you can only blow the engine.
Johnny
Member #: 6926
Accrington
i had an idea a couple of years ago about mixing liquid oxygen in with fuel? or injecting it. would that work or would it just melt the engine as if it had thermite in there?
pretty much the thermite route,
Nitrous oxide is 1/3 oxygen 2/3 Nitrogen, apparently the nitrogen acts as a coolant and using just O2 would not be good!
fab
Member #: 100
Paris\' suburb
if iy's about the engine getting hot, you are certainly not using enough advance , it will also help ith your boost feling. though be carefull with this.too much and byby.
