| Home > Help Needed / General Tech Chat > Pot Joints | |||||||
29th Oct, 2010 at 12:30:32pm
Did I read on here that not all A Series pot joints are the same?
29th Oct, 2010 at 12:39:27pm
Indeed there are two different sizes. On 13th Jul, 2012 Ben H said:
29th Oct, 2010 at 12:40:45pm
The "base" of the outer part of the joint is actually a small diameter pressed in steel cap - the hole with the internal splines is a through hole (to allow the splines to be broached) so is sealed after with a cap pretty similar to a core plug.
29th Oct, 2010 at 12:46:10pm
The play is around 5-10 degrees of rotation, say about 1-2 inches of free rotation.
744 Posts Member #: 7912 Post Whore Australia oi oi oi! |
29th Oct, 2010 at 12:48:22pm
use metal ties dude. looks nicer & don;t come off.
29th Oct, 2010 at 01:08:33pm
Apart from the reground re-con ones, there may have been a change to metric sized internals late in life. Metric balls are a lot cheaper than imperial sized ones as the vast majority of ball bearings and similar ball races are all metric nowadays.
29th Oct, 2010 at 01:22:04pm
Yes I need the proper tool, but first of all I need to get matching parts.
29th Oct, 2010 at 01:31:02pm
John bought one of those kits. The instructions where crap and we didn't get on with it. We ended up using cable ties and haven't tried again sinse On 11th Feb, 2015 robert said:
29th Oct, 2010 at 01:33:52pm
I think its cos the clips with it are crap. If something is worth doing, it's worth doing half of. |
29th Oct, 2010 at 01:42:50pm
I've got a tool like the one in your link Paul, its fucking shite to say the least, I've tried and failed to do a proper job with it.
29th Oct, 2010 at 01:52:03pm
This one then ?
29th Oct, 2010 at 01:57:01pm
My tool is the same as the "good" one Tom describes for the metal clips, like pincers but flat shaped ends, "borrowed" from work ages ago because we used to use similar clips with "ears" for gas hoses - but the version of the clip for gas hoses got banned by some H&S regulations so a few of the tools went missing :) Schrödinger's cat - so which one am I ??? |
29th Oct, 2010 at 09:51:37pm
I am not sure where the play is in your joints, but play can be had in the side cover bush, the diff output shaft and the offset sphere joint itself.
29th Oct, 2010 at 10:22:06pm
On 29th Oct, 2010 Paul S said:
This one then ? http://cgi.ebay.co.uk/PLIERS-CV-BOOT-CLIPS...=item2a0ad701a9 Paul, that is the one, but the clips he supplies are fit for the bin and the bin only. This is another guy who sells good quality clips.
29th Oct, 2010 at 10:22:45pm
On 29th Oct, 2010 Sprocket said:
I am not sure where the play is in your joints, but play can be had in the side cover bush, the diff output shaft and the offset sphere joint itself. If you decide on replacing the joints be carefull. I had a nightmare trying to get two off a diff earlier this year. We ended up removing the diff as a whole, drilling a hole in the core plug thing and twatting it very hard with the aid of a drift and 4lb hammer. The spring clip on the end of the shaft had large gouges in it from the splines and one broke in two. It turns out that, as I had been told by another member on here, the splines did not have a large enough lead on them, to allow the spring clip to compress! I know for sure there is another member on this forum will have the exact same problem when he comes to remove the joints from his LSD. |
29th Oct, 2010 at 10:24:42pm
This is the guy with the good clips
29th Oct, 2010 at 10:26:33pm
i remember this topic from last time, did anyone manage to find out the supplier off the dodgy stuff?
On 29th Oct, 2010 Star Mag said:
My new inner joints are just the same. I will have to modify them over the winter. On 29th Oct, 2010 Sprocket said: I am not sure where the play is in your joints, but play can be had in the side cover bush, the diff output shaft and the offset sphere joint itself. If you decide on replacing the joints be carefull. I had a nightmare trying to get two off a diff earlier this year. We ended up removing the diff as a whole, drilling a hole in the core plug thing and twatting it very hard with the aid of a drift and 4lb hammer. The spring clip on the end of the shaft had large gouges in it from the splines and one broke in two. It turns out that, as I had been told by another member on here, the splines did not have a large enough lead on them, to allow the spring clip to compress! I know for sure there is another member on this forum will have the exact same problem when he comes to remove the joints from his LSD. Yes i moved to the darkside |
29th Oct, 2010 at 10:44:21pm
I am not sure where the play is in your joints, but play can be had in the side cover bush, the diff output shaft and the offset sphere joint itself. If you decide on replacing the joints be carefull. I had a nightmare trying to get two off a diff earlier this year. We ended up removing the diff as a whole, drilling a hole in the core plug thing and twatting it very hard with the aid of a drift and 4lb hammer. The spring clip on the end of the shaft had large gouges in it from the splines and one broke in two. It turns out that, as I had been told by another member on here, the splines did not have a large enough lead on them, to allow the spring clip to compress! I know for sure there is another member on this forum will have the exact same problem when he comes to remove the joints from his LSD. It's the actual joint that has the play. Whether it will come off the diff easily or not remains to be seen. The gearbox is destined for the spares shelf anyway. Tom, Thanks for the lead on the clips. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
29th Oct, 2010 at 11:01:56pm
i use the metal bands, but the kit i bought has completely different clips to any of the above, still dirt cheap, but work a treat
29th Oct, 2010 at 11:05:21pm
heres the other thread with pics
30th Oct, 2010 at 08:31:10am
This one then ? http://cgi.ebay.co.uk/PLIERS-CV-BOOT-CLIPS...=item2a0ad701a9 What you talking about I bought this one on your recommendation Mr F? I used it with great success on my Passat and he is outside of Luton - I went and collected personally Paul! On 5th Sep, 2011 Vegard said:
30th Oct, 2010 at 11:13:44am
The tool is fabulous- but the clips he supplies (or the ones he sent with mine anyway) were crap.
31st Oct, 2010 at 12:11:13am
did you get the ones in the current pic? or the type in my pics?
