| Home > Technical Chat > Thinking out loud about squish | ||||||
![]() 1137 Posts Member #: 1450 Post Whore Near Paris - France |
9th Nov, 2010 at 05:11:34pm
Hi there,
Rusty by nature
They said "That sounds rough mate." I said "Cheers it cost me a fortune to make it sound like that!" |
9th Nov, 2010 at 06:23:47pm
according to Vizard (I watched ALL the videos Edited by Sprocket on 9th Nov, 2010. On 26th Oct, 2004 TurboDave16v said:
9th Nov, 2010 at 07:11:13pm
I was just thinking of the same thing ! I intend to have the block skimmed to flush those pistons that I had from you,Colin, to raise the CR a little, as they have such a deep dish.I dont want to skim the head.
9th Nov, 2010 at 07:17:38pm
ATDC meaning when the piston goes down ?
Rusty by nature
9th Nov, 2010 at 07:42:19pm
this 'squishing' effect promotes turbulence in the charge giving a better mix and promoting a better burn. i'm not sure if removing the squish band in one area is of any benefit.
10th Nov, 2010 at 10:16:07pm
http://www.davidandjemma.com/mazda/FAQ/quench.htm
520 Posts Member #: 2093 Post Whore Grenoble, France |
14th Nov, 2010 at 09:06:07am
I don't think you can control the point where the mixture is pushed in this kind of heads. The chamber in the head is much smaller than the piston's surface, it's very compact (which is good).
Edited by alpa on 14th Nov, 2010. std 998 A+, g295, MD266, RHF4, 109hp @0.8bar/5400rpm |
14th Nov, 2010 at 06:08:35pm
On 14th Nov, 2010 alpa said:
Skimming the block is a dangerous game as if you skim too much you'll create a small cavity which will be source of knock. This is what happens around the piston's crown, this is the most common place where knock starts. Not sure I understand this as it goes against what engine designers are saying. Skimming the block reduces the tendancy to knock. When you talk about small cavities, what do you mean? On 14th Nov, 2010 alpa said:
You can pay attention to how you screw spark plugs, in order spark is well exposed to the mixture. This is an old trick everybody seems to have forgotten. Mr Wiginton manufactures and sells Spark Plug Indexing washers, so not everyone is ignorant of this fact
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=308471 On 26th Oct, 2004 TurboDave16v said:
15th Nov, 2010 at 09:08:49pm
I came to understand that a squish that is the thickness of the head gasket prevents from knock (and I am now trying to understand if it is what is reffered as quench).
Rusty by nature
18th Nov, 2010 at 02:07:37pm
Skimming the block is a dangerous game as if you skim too much you'll create a small cavity which will be source of knock. This is what happens around the piston's crown, this is the most common place where knock starts. Not sure I understand this as it goes against what engine designers are saying. Skimming the block reduces the tendancy to knock. When you talk about small cavities, what do you mean? I mean studies show knock starts in cavities where temperature and pressure are high. Today engine designers talk about modern engines, nobody designs engines like ours today. You'll never see heads like in Mini. Keeping 1mm between the flat head surface and the (flat) piston can be a source of knock in a turbo engine running 2500rpm. The basic idea is that mixture should be at the same pressure (and thus temperature) everywhere in the chamber to make front propagation uniform (I'm talking about power, not consumption) thus predictable. Cavities are local areas of high pressure -> high temperature. Cavities far from spark are placed under high pressure a long time before the flame front reaches them, so they can auto-ignite and create a counter-flame, which is the knock. Additionally sharp edges of the head are hot spots -> source of high temperature and auto-ignition. And of course skimming too much means risk of piston to head collision. Modern engines are built of better controlled materials and have less plays, they have 5 or more main bearings. std 998 A+, g295, MD266, RHF4, 109hp @0.8bar/5400rpm |
18th Nov, 2010 at 08:19:12pm
Funny then that the last 1,2 from VW has parrallel valves and shrouding much alike the A-series.
Rusty by nature
) if the distance the piston from the head at the squish band is around 0.100" at 14 degrees ATDC, the engine is more prone to detonation. The theory being that a smaller gap (< 0.100" at 14 degrees ATDC) will cool the un burnt charge with the piston and head surface helping it to resist spontanious combustion or by quenching the flame. Visard recons if the only thing done to the engine is skim the block to bring the pistons to the top of the block, thus actually increasing compression, the detonation problem normally goes away.
