Home > For Sale > GT20 Turbo and Tuftrided Crank
retroracer1380
Member #: 1972
Worcester
Postage not included in prices:
GT2056 Turbo part number 751578, just removed from a iveco daily 2.8 im breaking. Very good condition absolutely no play, doesnt look very old.
£200
Factory Tuftrided 1300GT crank, 12G817, Standard size but could do with a grind
£40
Edited by retroracer1380 on 21st Nov, 2010.
DaveVader
Member #: 9075
Peterborough
ooh ooh ooh!
Getting my name in for the GT20
Just need to check on funds etc.
What's up with that crank?
It's a CAM1505 with the 1505 grinded off and a new number stamped in it's place?
Is this from the factory?
maybe some kind of refrence?
retroracer1380
Member #: 1972
Worcester
The factory tuftrided cranks, were a 12g1505 forging, but before be tuftrided had the casting number ground off, and were stamped up
I thought this would be the case.
Would this be a good crank for offset grinding for strokers then?
It also adds more fuel to the fire about the CAM6581 CAM6232 cranks. As these are cast with the different numbers.
retroracer1380
Member #: 1972
Worcester
Yes would be a good crank to offset grind, but would probably need hardening again if grinding the big ends to S size when stroking, as tuftriding only hardens the surface
It's interesting. I remember seeing a 6581 that had been stamped like this over 6232.
Me 2
Probably this one
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=7112
That's the one.
Ps sorry for the hijack
retroracer1380
Member #: 1972
Worcester
Turbo sold, crank still available
