Home > Technical Chat > Gt17 turbo flanges
Dub-disaster
Member #: 8871
yeovil,somerset
Hi all, having a custom turbo manifold made up and wondering what flange is best to put on it I know the bolt pattern for the gt17 is the same as the t25 flange but I would like the scope to change to a t25 or gt20 in the future if I want to. But I currently want to run the gt17 can you use a gt17 on a t25 flange if so is it direct fit or would it be better in the long run just to go for a 38mm hole like the gt17.
Oh and finaly gaskets if you where to use the gt17 on a t25 manifold would the gasket be a problem ? If so I'll just plump for the 38mm round hole. Thanks in advance
Paul S has some GT17 and GT2056 flanges laser cut for sale here:
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=341617
Edited by apbellamy on 9th Dec, 2010.
I'm pretty sure that the stud pattern is identical on all the turbos you mention above.
It's just the size of the hole that will differ.
Dub-disaster
Member #: 8871
yeovil,somerset
Exellent, one more question if I was to fit a gt17 to the t25 square hole flange abd use a t25 gasket would this work ok or be better to go for round hole flange and genuine Saab round hole gasket ? Just wanted to know of any one has used the gt 17 on the square hold falnge and what gasket they used realy ?
Thanks again, I'll get in contact about those nice flanges
Pfft nice flanges lol,
I'm pretty sure robert squared out the inlet on his gt17 to match the metty manifold,
gasket wise, just use a large square one,
I smoothed mine to match the t25 gasket.
jamestar
Member #: 9159
Devon
slight hi-jack but i've been meaning to ask this, got the gt17 to go on my t3 exhaust manifold, so most people have just squared it off.. no adaptor flangers?
and have most people re-drilled the studs or just slotted the bolt holes on the gt17?
I believe Robert slotted his. Paul S has adaptor plates in the lin above
Disk full (/tmp/#sql_c9d4b_0.MAI); waiting for someone to free some space... (errno: 28 "No space left on device")
