| Home > Technical Chat > Which Cam ? | |||||||
809 Posts Member #: 224 Post Whore Katy TEXAS |
7th Mar, 2005 at 02:15:37pm
Could anybody Advice please, BTW - I took my buddy VTEC Pete out for a spin this weekend, and even though I am running her in, he gave it a name, the "Brocket"...cause I'm a brocket maaannn, nah nah nah nah nah nah nah nah nah nah nah....
7th Mar, 2005 at 02:51:49pm
I have used all the 3 mentioned cams in a turbo'd an A series. The N/A mg cam offers a very long exhaust duration with suits the turbo no end.
7th Mar, 2005 at 03:13:23pm
I'm going back to an MG cam at the next build... I think there is a little too much overlap in the ph2 for higher boost levels (which will be made even worse if a smaller exhaust housing is being used)...
Edited by turbodave16v on 7th Mar, 2005. On 17th Nov, 2014 Tom Fenton said:
7th Mar, 2005 at 03:18:39pm
How much difference is there between the N/A MG and the phase 2 cam 5 to 10 BHP ? Hard to answer I know. .. Also how much boost can you get out of a standard waste gate without using a bleed valve. I mean by just adjusting the pre load or do you run out of actuation length ?
Edited by Brocky on 7th Mar, 2005. BTW - I took my buddy VTEC Pete out for a spin this weekend, and even though I am running her in, he gave it a name, the "Brocket"...cause I'm a brocket maaannn, nah nah nah nah nah nah nah nah nah nah nah....
7th Mar, 2005 at 04:12:46pm
Like you say - hard to answer! The ph2 probably makes more power upto 12/14psi, after that, the MG would make more power I reckon, especially with a stock turbo unit with the 0.25AR turbine...
591 Posts Member #: 360 Stu from Corwall aka Mr Jazz Piano, Love_Machine, kneegrow |
9th Mar, 2005 at 08:48:54pm
Dave, which rockers are you running with that?
Bugger off, I'm getting there. |
9th Mar, 2005 at 11:08:15pm
For fuck sake, just try 1
10th Mar, 2005 at 12:38:52am
Very good point there about the scavenging. I'll do some proper testing when I get my proper engine built. I still go along with the 2L engines don't have 29mm exhaust valves though.
169 Posts Member #: 409 Advanced Member Bristol |
10th Mar, 2005 at 12:43:28pm
I use a MED/ Piper T3 Cam, which I would recomend!
Hannibal: There are two ways we can do this: the easy way and the hard way. In a few minutes my friends and I are going to come down on you like your worst nightmare. You're gonna wish the Earth had opened up and swallowed you whole.
10th Mar, 2005 at 01:31:43pm
Most peeps - given the figures are identical to the Avonbar ph2! On 17th Nov, 2014 Tom Fenton said:
![]() 368 Posts Member #: 362 Senior Member durham area |
10th Mar, 2005 at 08:35:46pm
Is anyone runing a KENT KCM500 whats the thoughts? love that straight cut scream!!!
10th Mar, 2005 at 09:19:14pm
think WilH is going to.. |
11th Mar, 2005 at 08:29:26pm
Just for the book, what are the durations of the Ph3? Bugger off, I'm getting there. |
11th Mar, 2005 at 09:12:44pm
Well the Kent500 is a carbon copy of the MG Metro Cam, so I guess it's what i'm swithching to! D On 17th Nov, 2014 Tom Fenton said:
84 Posts Member #: 255 Advanced Member |
15th Mar, 2005 at 10:13:36pm
Runnin a Kent 500 cam at the moment. Its got manners, as opposed to the Ph3 cam I tried to start with.
16th Mar, 2005 at 01:58:00am
Well look above - it's a lot of theory - YOU have tried it and proven something - big duration is not neccesarilly needed on a turbo cam for power. On 17th Nov, 2014 Tom Fenton said:
16th Mar, 2005 at 07:49:11am
NextGen, I have exactly the same story to tell about the KC 500 and the Avonbar P2 cam. The problem I had was I could never get the wheels spinning so it always bogged down with the P2.
9 Posts Member #: 497 Junior Member |
16th Mar, 2005 at 09:16:29pm
Well i was running a stock 1100 cam in my 998 Turbo (yep, its me guys, James_be from the now way-too political MM board....)
Edited by kazjim on 16th Mar, 2005. Erwin, what have you been doing to that cat, poor thing looks half dead: mrs schrodinger. |
16th Mar, 2005 at 10:08:18pm
Hi James!
16th Mar, 2005 at 10:13:02pm
Huge Lift... (running STOCK PRESSED rockers) the Midrange is incredible with tyre spinning from about 4500-6000 if not controlled ! (Yoki A008's 165/70/10)
17th Mar, 2005 at 06:06:30pm
Good to see your still around James, and still got your 998 ! |
) or shop around for deals on actuators...
