| Home > Technical Chat > oil relief/oil return | ||||||
64 Posts Member #: 6668 Advanced Member |
2nd Feb, 2011 at 03:13:39am
Hello Guy's, I am looking to modify the oil relief hole to exit into the drop gear area I think i saw this mod on one of the forums. The engine is apart now so i thought this would be a good time to do it. This is for the race car so it sees sustained 8500 redline a lot and all that oil getting shot at the crank can't be good. Pictures or a link would be good too. Aaron Racecar spelled backwards is Racecar |
4th Feb, 2011 at 11:34:57pm
I can't believe no response. This should be an easy one since i see undercrown jets and super high end modifications here all the time. To make it more clear the relief hole in the bottom of the block shoots right into a relief cast in the transmission and deflects it right into the crank. got to be a way around that. Aaron Racecar spelled backwards is Racecar |
4th Feb, 2011 at 11:37:53pm
Hi mate i thank jim has this done on his setup. I have started posting on Instagram also my name on there is turbomk1golf
4th Feb, 2011 at 11:52:22pm
5th Feb, 2011 at 12:28:08am
Hello guys, Not the same mod but the stuff Harry comes up with... Wow. the mod i remember was a copper tube pressed in the the area where the drop gears are and run down into the lower case with the original oil hole plugged. i still think it was here that i saw it. Aaron Racecar spelled backwards is Racecar |
5th Feb, 2011 at 12:55:48am
just drill a hole in the rear end of the block so that it intersects with the original passage for the drain, job done. On 26th Oct, 2004 TurboDave16v said:
![]() 1596 Posts Member #: 8027 Post Whore Thrapston, Kettering, Northants NN14 |
5th Feb, 2011 at 01:40:03am
think im going to tap mine into the gearbox casing. dumping it straight back into the sump... anygood? Edited by Rick.SPI on 5th Feb, 2011. On 17th Feb, 2011 apbellamy said:
I popped my first one out the other day... |
