Home > Beginners Tech > inlet manifold takeoff for mj/boost gauge etc - optimum position?
welshdan
Member #: 1111
s wales
hi, im going to drill and tap my inlet manifold so i can fit my megajolt and a boost gauge.
i know i will have to drill and tap for the fitment of a take off on the flattest part.
however, is there an optimum place for this, ie closer to the carb/closer to the cylinder head or does it not matter?
many thanks
dan
not sure about the best place,
but if your using a metro inlet,
as you look at it one the car,to the left side there is a little raised area,maybe from the casting?
i have just drilled and tapped that,seems to work ok,
or you could Tee out from the regulator signal pipe??
TurboTom
Member #: 7936
DK-8450 Hammel. Denmark
On most manifolds there is a take off point for the brake servo.
i have drilled a hole in the center of the bolt and tapped it for a small banjo bolt.
I don´t think one place is better that an other but i don´t have the facts to back up my allegation.
If i have more toys than you when i die, I WIN
Johnny
Member #: 6926
Accrington
this may help
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=382992
welshdan
Member #: 1111
s wales
cheers for the input chaps. i was looking through my turbo parts earlier and there is a manifold with a banjo for the servo, and a take off added to the top of that. i think i will use this and all a T piece there for the two functions that i require. many thanks again
