| Home > Help Needed / General Tech Chat > Oil Cooler | |||||||
![]() 163 Posts Member #: 9181 Advanced Member Rhoose, Cardiff |
8th Feb, 2011 at 10:21:18pm
Hi everyone
My project Toyota powered mini: http://www.turbominis.co.uk/forums/index.p...tid=470448&fr=0 |
8th Feb, 2011 at 10:23:41pm
get an oil temp gauge in there and test it.
8th Feb, 2011 at 10:25:09pm
What sort of temperatures would say is getting on the hot side? My project Toyota powered mini: http://www.turbominis.co.uk/forums/index.p...tid=470448&fr=0 |
8th Feb, 2011 at 10:37:42pm
Anything over 120 degrees C If something is worth doing, it's worth doing half of. |
8th Feb, 2011 at 11:10:42pm
ok thanks My project Toyota powered mini: http://www.turbominis.co.uk/forums/index.p...tid=470448&fr=0 |
9th Feb, 2011 at 12:04:47am
I'd be worried if oil temps regulary saw 120c, and even if they just frequented, i'd be wanting to fit an oil cooler to try and maintain an oil temp of around 90c.
9th Feb, 2011 at 09:02:15am
Don't we agree that the oil should be above 100deg? If not, water won't disappear. On 13th Jul, 2012 Ben H said:
9th Feb, 2011 at 09:28:02am
I think that an oil temp of around 100deg is about ideal.
9th Feb, 2011 at 10:08:47am
On 9th Feb, 2011 Vegard said:
Don't we agree that the oil should be above 100deg? If not, water won't disappear. We have discussed this before, and the oil temperature does not need to be above 100c for water to evaporate. How do you think cloths dry hanging on the line at 20c? On 26th Oct, 2004 TurboDave16v said:
9th Feb, 2011 at 10:59:17am
Don't we agree that the oil should be above 100deg? If not, water won't disappear. We have discussed this before, and the oil temperature does not need to be above 100c for water to evaporate. How do you think cloths dry hanging on the line at 20c? Magic? :) On 13th Jul, 2012 Ben H said:
![]() 514 Posts Member #: 5362 Post Whore wexford in ireland |
9th Feb, 2011 at 11:02:17am
Don't we agree that the oil should be above 100deg? If not, water won't disappear. We have discussed this before, and the oil temperature does not need to be above 100c for water to evaporate. How do you think cloths dry hanging on the line at 20c? fairys? On 5th Jan, 2011 wolfie said:
he floated over to mine for a bit of ring |
9th Feb, 2011 at 10:09:11pm
Ive got another question that is sightly off topic.
9th Feb, 2011 at 11:00:59pm
sorry ignore the last post, i found another thread on it My project Toyota powered mini: http://www.turbominis.co.uk/forums/index.p...tid=470448&fr=0 |
9th Feb, 2011 at 11:39:46pm
I'll bet you did.
84 Posts Member #: 2404 Advanced Member Braintree, Essex |
9th Feb, 2011 at 11:46:53pm
Don't we agree that the oil should be above 100deg? If not, water won't disappear. We have discussed this before, and the oil temperature does not need to be above 100c for water to evaporate. How do you think cloths dry hanging on the line at 20c? Wanna talk about vapour pressure some more?
Geoff |
