| Home > Technical Chat > best megajolt map for running in | ||||||
![]() 514 Posts Member #: 2104 Post Whore Essex - UK |
27th Apr, 2011 at 01:52:14pm
im just trying to decide what map to run my new engine in with i was thinking of using a std metro turbo one as it will be going to a rr for setup once its been run in.
"Tuning should be a compromise between what is possible and what is necessary"
27th Apr, 2011 at 01:55:17pm
Its not critical if you are running in, surely ?
27th Apr, 2011 at 02:07:37pm
i have a electronic boost controoler so it will be off and runnign the standard 6ish psi so its not a boost issue im on about.
34 Posts Member #: 4608 "Member" |
27th Apr, 2011 at 02:58:14pm
imo if u can get a ignition map that emulates the stock turbo distributor then that should be sufficient |
27th Apr, 2011 at 04:18:25pm
This thread any use
![]() 736 Posts Member #: 1865 Post Whore Norwich, Norfolk |
30th Apr, 2011 at 10:32:08pm
i'm going to be runing mine in at 26 degrees across the board. Edited by Simon on 30th Apr, 2011. |
