Home > Help Needed / General Tech Chat > smoking, seals pushed up
eden7842
Member #: 8852
leicestershire
my new engines started smoking mainly on idle, 2 of my mates think its stem seal as its fine when im driving.
the engines only done about 150 miles so could it be still running in?
if not is there a tool to change the stem seal without taking the head off?
hopefully you can put my mind at rest
cheers eden
Edited by eden7842 on 9th May, 2011.
To quote....
"Run the cunt in. This is it!"
Jack the front of the car up nice and high. If the smoke stops, it's likely to be valve guides/seals.
possibly worn valve guides in the head. WE had that problem with the van, when not on boost the turbo was sucking oil into the exhaust.
eden7842
Member #: 8852
leicestershire
in that case then i rekon it just wants more miles. As the guides havent long been done and i did fit new seals wen the engine was built, just not the best 1s
adamt
Member #: 9181
Rhoose, Cardiff
I guess im not the only one with a smokey engine lol
My project Toyota powered mini: http://www.turbominis.co.uk/forums/index.p...tid=470448&fr=0
eden7842
Member #: 8852
leicestershire
wng691s clubby
Member #: 9252
Cleethorpes
iv just had too change mine smoked when i set off left a big cloud behind me but was fine whilst driving
Done now needs redoing lol
eden7842
Member #: 8852
leicestershire
il run it in to brighton and change them after
jimmy
Member #: 829
essex
it sounds like valve guides to me
1293 Turbo mini
eden7842
Member #: 8852
leicestershire
so ive took the rocket cover off to find 3 exhaust and 1 inlet seal had pushed up. is there anything i can do to fix this without taking the head off?
You can push em back down with a screw driver.
eden7842
Member #: 8852
leicestershire
ive done that for now just wonered if there anything i could do to help them stay down?
Utking
Member #: 9342
Southern Norway.
Glue? *tongue*
eden7842
Member #: 8852
leicestershire
wel thats basicly what i was thinking, the bad news is the covered in oil atm
disconnect the turbo ?
What guides/seals are you running?
eden7842
Member #: 8852
leicestershire
not a clue, payen seals
